Post your photos of 3 inch lift with 32" tires
frohbego
Can anyone post photos if they have a 3 inch lift and 32" tires. I just put on the SS 7.2 kit and bf goodrich 32" tires.
Corey
OverCamping Specialist
Old Man Emu lift and stock size tires in a mud tire.
I switched over to 285x70x17 (33s) later that summer.
The smaller tires looked a little out of place with the lift.
Those look good on your rig, but 33s would fill the wheelwells better.
RMP&O
How about 2.5" lift with 33" tires!?
Next to my other truck that sits on 40" tires...
main.php
main.php
main.php
frohbego
How do you like your 33"s?
Yeah i was really back and forth between 32" or 33"
i Got the 32"s b/c its my daily driver and i'm only doing mild trail offroading once and a while.
So far i really like the look. Lift and tires were just put on 3 days ago so i think the lift will settle a little bit to help balance the look out.
Mr. Leary
Glamping Excursionaire
The biggest difference I noticed was in power between 32s and 33s. 33s put you right below the power curve with 4.11 gears, making the truck pretty sluggish on hills.
I have a 1.5" BL, and had OME heavies for a while until switching the rear coils out for heavier OME Prado coils. My total lift is around 4", so slightly higher then your present setup.
Hang on for a minute while I vomit pictures all over your thread...
Here are some pics of my truck in 32s:
MotoDave
How about 0" lift and 33x10.5R15's ... but its on a T100 (31's stock) :)
Now I need to work on making it flex more ...
Clemtiger84
