3rd brake light
So here is the 3rd brake light I installed it is nothing fancy but works great and looks like it is supposed to be there.
It is an LED light, that I took it off an 92-99 model Suburban at pull-a-part and paid only 2 dollars for it. This light can also be found on some other GM vehicles, so pretty much every junk yard will have one.
The installation was fairly easy, I drilled 3 holes, one for the wires and one on each side of the light for the mounting screws. On the bottom of the light is a gasket to seal it to the roof, I coated that and the screws with some silicone sealant to make sure it does not leak around the holes.
Then I grounded the negative wire to the frame and the positive to the right brake light wire. Right now it works but it will flash when you turn on the right blinker because there is only one wire for both the brakes and blinker so I have to find out where the brake light switch is located and then wire it to there instead of the light.
I missed this one:
Can we ask how much you payed for that wicked Burb?:Wow1:
I paid 1700 for it, when it was mostly stock, it did come with the black roof box. And the engine and trany are both rebuilt with about 30k on them.
