‘23 F-150 Raptor to Get 700-horsepower, Supercharged V-8
AbleGuy
Officious Intermeddler
2023 Ford F-150 Raptor R First Drive Review: The 'Big Raptor' gets the big V8
Up until very recently, there was only one Ford Raptor — no Ranger, no Bronco, just the F-150, or as its engineering team likes to call it, “Big Raptor.” The OG. The king. In Big Raptor’s little corner of the Ford Performance world, bringing the V8 back was always a matter of when, not if. But the realities of the market held sway and other projects took priority — including an overhaul of the truck’s suspension. Then TRX happened.
… In plain terms, we now have the…700-horsepower, supercharged F-150…
The new 2023 Ford Raptor R benefits from an existing Raptor framework. The evaluator seems to says that in this case, the R is basically the regular Raptor with mainly a bigger, more powerful engine residing under the hood.
“ Apart from some visual details and swapping a few suspension components to account for the weight of the V8, the Raptor R really is just a more powerful Raptor with the 37-inch tire option made standard.”
The article goes on to point out:
‘Specifically, adding the GT500’s 5.2-liter supercharged V8 pumps things up to 700 hp and 640 pound-feet of torque from 450 hp and 510 lb-ft with the 3.5-liter turbo V6.”
The heavier R’s stiffer springs maintain a similar ground clearance as the V-6 Raptor’s 13.1”, while running with 37’s on it. The other important off road angles…approach, breakover and departure…stay the same too, as well as the its suspension travel (13 inches up front and 14.1 in the rear).
(From the story) “The Raptor’s engineers tinkered with the drive modes a bit for R, changing the default Sport Mode powertrain setup to be the automatic 4WD setting (it’s 2WD in the standard Raptor) in order to put all that power to good use. The standard 37s on the Raptor R don’t do the truck any favors off the line, and in fact may keep a drag race between the R and the TRX perilously close, but the V8 can still rip that off-road rubber to shreds if that’s what you’re going for. We were only given the opportunity to practice acceleration runs on sand — useless for data gathering, but immensely fun.
The differentiation is minimal in practice, too. Setting aside the Raptor R’s dramatic acceleration, the drive is virtually identical. That’s a good thing, and due at least in part to the fact that minimal alterations translate to minimal weight gain. The R weighs roughly 5,950 pounds — about 100 pounds more than a V6 Raptor with the 37s (or 200 pounds more than without). Yeah, that’s a hefty curb weight, but remember that the iron-block Hellcat V8 in the TRX helps push that all-steel truck north of 6,350 pounds. The Raptor’s comparatively lightweight aluminum body gives it a pretty serious edge”
Click on the link below for the rest of the write up ⬇
And the summary of the author’s driving experience of this powerful new F-150 model?
“The Raptor R is everything it appears to be. It’s big, boisterous and willing — every bit the equal (at minimum) of Ram’s Hellcat-powered TRX. The V8 is straight-up nasty, with an off-road exhaust mode that will liquefy children’s ear drums. It’ll do everything the V6 Raptor does just a little bit quicker and with a whole lot more fanfare. If that’s ticking your boxes, then you’re in business. Hopefully business is good, because you’ll be forking over a six-figure sum to get one — $109,145 to be precise, at least before any dealer shenanigans.”
I've already driven a Raptor R. Its pretty cool; The rear end feels more planted than my Gen1 (I'm working on fixing that). I don't think it will be much of a seller with any of the audience of this forum, not to say that a Raptor R owner won't wander onto ExPo and slap a roof top tent onto their truck. The Raptor has evolved more and more away from its "F150 some fancy suspension bits" to essentially its own model and now its own range/brand with the introduction of the Bronco Raptor and Ranger Raptor. The Gen3 and Raptor R even moreso than the original run of Raptor is aimed at people who are either so far into the hobby of taking their truck down to SoCal and Baja that they don't care about beating on their 100k truck or people who just want the social media clout. The original Gen1 had as nice of an interior as the Lariat AND WAS CHEAPER, now the Raptor R is the most expensive F150 not named Lightning.
Recently I was asked if I was going to replace mine with a GEN3, and honestly the GEN1 holds up so well. The only thing that is starting to lag behind is the SYNC2; They still put out updated navigation SD cards but you can easily upgrade to SYNC3 with all the benefits of Apple Carplay and Android auto. The 6.2 is a lazy engine, so its never going to pushed to its limits, and are known to last forever; compared to the 5.2 which has forced induction and seems to be playing with fire a bit more (not to say its not excellent or reliable). I think a naturally aspirated 7.3L Raptor would interest me a bit more, and I don't have a fully fleshed out reason why. With only 80k miles (despite having driven cross country twice), I'm gonna hold onto my truck and keep tinkering with it and have it be my adventure vehicle, tow rig and occasional daily driver for at least a few more years.
Despite how cool the Raptor R is, I don't yearn for it and I cant justify buying it and that kind of ruins it for me. When I purchased mine I could absolutely justify it; I wanted a truck, I had the prospect of a growing family (that didn't end up happening) so my RX8 was no longer viable, and I could finally afford something new. Now, I could still probably afford the Raptor R, but a 2 door Bronco Sasquatch does so much more emotionally for me.
Jlbeats
