01’ TJ serpentine idler pulleys
ryanhewitt
Can someone confirm that both serpentine idler pulleys are the same - the stationary one that goes to the block/head and the one that moves/tensions the belt? I lost the entire movable one, dealer states same but their diagram clearly shows one smooth one grooved.
01’ tj 6 cyl a/c
Thanks in advance!
Ryan
NatersXJ6
If the system is properly aligned, you should theoretically only need 1 grooved pulley to maintain belt alignment. Some systems use more, but it should be okay as long as there is 1.
Why would you choose to source idlers from a dealer for an ‘01? Any auto parts store should have complete idlers and tensioner idlers.
ryanhewitt
Thank you both for the quick replies. NatersXJ6, I stopped going to my local auto parts store as nothing was ever in stock. I did check, and yes they have both in stock. Guess I need to check with them in the future. Also on my 01' both are smooth, stationary is 3" metal, and movable is 2&3/4" plastic.
Thanks again!
Ryan
