austintaco
I have an 03 Double Cab that I am trying to devise a roof rack system for. I bought a used Con-Ferr rack that I want to be able to switch out between this truck and my 84 4runner. For that reason, I want to go with a factory rail system that will allow me to use the mounting plates that Defenderracks sells for factory applications.
I don't want to go with Yakima or thule because I don't like how high the basket will sit .
I have a shell on my Tacoma, but its higher than the cab, so mounting the rack on top makes it look like I am building a pyramid back there.
I pulled two complete roof rack assemblies from 2nd and 3rd gen 4runners to see which one works best. The rails are the same style with only slight differences in length and width between the two generations.
Has anyone on here used a factory rail system on doublecab? How did you do it? Backing plates, expanding bolts?
Anyone on here have a rack mounted like this with a Sunroof or moon roof? I have a wild hair to have one put in at the same time, but not if its going to compromise the roof. Looking at the Webasto Hollandia 700 or a Webasto pop up. Its just something I have always wanted in the truck
