'04 DC with 235/85 r16
toyota_jon
Here's a few shots for reference. I just put some new 235/85 r16 BFG AT's on the truck. Truck is all stock (for now). No problems with rubbing, and traction has been excellent with the packed snow and ice we've had here recently.
Louisd75
Do you have any pictures of it almost straight on from the front that you could post? From the side and with the mudflaps it looks remarkably similar to a 265/75/16 :elkgrin:
esmirna8261980
this is a 2005 with 5100 all around and coil also adjustable uca the tires are Cooper sts 255/85/16 the rims are toyota baja edition
realjeepsrust
hi, i was wandering how your fuel mpg's are now that you have the 235's on? i put 235 cooper st maxx's on my '01 dc and lost about a 1.5 mpg. thanks
juicebox
You probably didn't lose that much. Are you compensating for the change in your speedo? Use a gps to check your speed, then calculate how much it's off by. I went to 33x10.50's, Mine is off by about 7-8%.
Example, 310 miles traveled, 310 x .07 =21.7 so 310 + 21.7 = ~332
So, if my truck says I've gone 310 miles, I fill up with 18 gallons, that's ~ 17.2 mpg
actual miles traveled - 332 / 18 = 18.4.
On my last trip, I went from Cedar City, UT to Flagstaff, AZ in one tank. When I calculated my mileage from the ODO, it was like 17.5 mpg. Then I got on Google maps on my iPhone, dropped a pin on the map at the exact gas station where I filled up, then at the gas station where I filled up in Flagstaff. I calculated like 19.5 mpg.
jim65wagon
Not that he shouldn't compensate for his tire size, but I also lost 1.5 mpg by putting on the Cooper ST Maxx's. I run a TruSpeed Recalibrator on the Tundra and it is spot on at 65mph. I also just read an article on the ST Maxx and the author also noted a mileage loss......
Toyotero
Jon,
Now that it's been a couple of years, what would you say about your experience with the 235/85 r16 tires and factory suspension?
Cheers.
p nut
butter
Jon,
Cheers.
Just my input. I had the exact same 235/85's on my old 01 DC. Mine rubbed the frame a tiny bit at full lock. No real issues with running this size tire. Only available in LR E, which some people said would ride too harsh. I didn't find that to be true. It performed ok on and off-road.
What I didn't like:
- Off camber turns were more tippy than a comparable 265/75 tire. Both on and off-road
- No observed MPG gains over 265/75
- I like narrow tires, but I thought they were *too* narrow
Only real advantage to go 235/85 is the cost of the tires. For me, the negatives outweighed the cost, so won't be getting this size tire again.
Toyotero
Ultimately, I'm wondering if 265/75/16 will be good w/o suspension life on my 03 DC Tacoma. From the various posts I've read around the internet it seems like its a good fit with no rubbing other than frame at full steering lock.
MtnClimber
Ready To Explore!
I ran 265's on my 01 DC with stock suspension/rims with no rubbing or any issues.
p nut
butter
I had slight rubbing at full lock AND compression. No issues commuting/daily driving. They look just right on a stock Tacoma.
