04 Disco towing Conqueror
elmo_4_vt
I am finishing a M101 with Flippac and will use the D-I and D-II without concern. Both have +2" OME and the D-I has D-90 front brake upgrade. The D-II is rated to tow 5k I believe. The on highway is tougher d/t braking, offroad it will do fine. I used a 130 Tdi to pull my Base Camp
I need to see pictures of that trailer... To keep on topic, I don't believe you could tow it unless you show pictures of the trailer... :eek:)
andyrad
The 4.6 is gutless at the best of times if your truck runs bigger tires and a roof rack, so I was expecting it to be worse with the trailer but it was not that bad. I had no OME extra heavy springs in the rear so it didn't weigh it down and it pulled it no problem.
scottma
Here you go . Link to my Album in my Signature
flipstick
