BlackjackT7
2006 Econoline 350, 7 passenger, with 6.0 turbo diesel and Quigley 4X4 Conversion
Engine is 6.0 Turbo Diesel
Rebuilt by Barr’s diesel March of 2014
Turbo Rebuilt by Barr’s Diesel
ARP head studs, stock ford head gaskets
EGR delete
Full Force Diesel 155cc Injectors
3 Innovative diesel custom tunes (for the upgraded injectors, EGR delete)
3 First coast diesel custom tunes (Stock injectors and EGR delete)
IPR coolant filter kit mounted on frame rail
New radiator, water pump, hoses, alternator, oil cooler
Spal cooling fan on transmission oil cooler
New transmission and transmission oil cooler replaced at Ford with ford warranty August 2014
Wheel bearings have been replaced
Newer tires %90 tire left
Full size spare
Rotors are newer with Hawk pads, also have a set of brand new (uninstalled) Carbotech pads made for this application
Read-Head steering gear box
Ball joints, tie rod all have been replaced recently
Rear suspension has Air Lift 5000 with load controller and compressor, you can adjust the air in each bag independently on the fly by a controller in the dash.
Auxiliary power source wired into the battery with attachment point by the trailer hitch. Custom set of jumper cables that plug into this PTO. You could also use this point for a winch or other auxiliary system.
Aluminess aluminum roof rack with adjustable bars and dual rear boat rollers for easy loading of kayak’s
Currently miles are sitting at 193,000
Price $35,000 OBO
Contact Jack Switzer
317-508-6369
EGR delete
Full size spare
Price $35,000 OBO
317-508-6369
