mgmetalworks
I don’t know about you guys but ever since the updated E-Series styling in ’08, I just haven’t felt like the trailer tow mirrors for the van look right. They’re functional and serve their purpose but to keep consistent with the grill/headlights/bumper styling, the mirrors should follow the same kinds of lines. The Super Duty truck mirrors updated in ’08 but Ford decided not to update the van mirror styling, probably because the E-series was to be discontinued and the mirrors between the truck and the van share very few interchangeable parts.
The other thing that disappointed me was that after driving a new F350 with power telescoping, power folding, heated, turn signal mirrors, I realized that the van mirrors, though functional, kinda sucked compared to the truck mirrors… I found that the bottom convex mirror from the truck was much better for spotting cars in my blind spot and provided a great view of the surroundings when backing up. Not to mention the power folding for pulling into tight parking spots! Going back to the van with the little sliver of a mirror, I started looking into what it would take to make the swap.
Basically, it takes a lot of work to do this from scratch. The truck and van mirrors are VERY different in how they mount to the door. Different size, different position, different angles… You’re not going to take a truck mirror, drill a few holes in the van door and be done. What I’ve done is designed a new mounting base for the truck mirror to work on the van door. I’m also in the process of designing a new plastic shroud for the new assembly that will keep the same styling as the truck mirror.
I hope to be done with this project within a couple months and make this conversion available to others as a bolt-on upgrade. Here are a couple pictures of the ’08-current truck mirror mounted to my van using my prototype mount. I’ll be working on the mock up of the plastic shroud this weekend and I’ll post more pictures as I progress.
You can see a big difference between the old mirror and the new one. I'm loving the look!
