I'm using a standard 20lb. tank. For the bottom ring, an 8" pipe formed the base support which perfectly went around the bottom ring. For the top support, I used this bracket off Amazon:
I didn't get much done today, just put the frame up on blocks to dis-assemble the suspension (to finish priming and painting), and cut some of the wood for the floor. Unfortunately that's about all I'll get done this weekend, we're going to Canada to see the in-laws.
I'm using 3/4"... Excuse me, 23/32" for the flooring, it's solid project grade (very few, if any knots but not absolutely smooth.) It will be sealed and undercoated. When I do the sides, I will be going to marine grade 1/2" as the outer of a sandwich using hard foam insulation.
Thanks! I was curious of using 1/2" Advantech (from Lowe's) for the flooring of mine, which the floor is only 41"x71" (roughly). I s'pose I'd coat it with something too.
I could probably get away with 1/2" with all the metal bracing in the frame, but i just wanted a little more strength on the bottom for "impact resistance." I'll use 1/2" for the bed area.
Today was as much about testing construction theory as it was about actually building. I only bought one sheet of metal because I wasn't sure if I'd actually be able to form it to meet my needs.
My plan was to use a 2 X 4 (with one side shaved to form a sharper edge) as a poor man's sheet-bender.
With a little tapping of the hammer after bending each side, the final product wasn't too shabby, even if I say so myself!
Here's the test fit into the frame after installing the hatch. The hatch actually attaches to the trailer frame, not the sheet metal sides.
And, here's the final sealed & primed product.
Tomorrow, I'm going to be working on the flooring and the battery/water tank area.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
