'12 Nissan Frontier sleeping platform
thevulture
Hello all, I've lurked on here for awhile and now have something to share. I built up a quick, easy and cheap sleeping platform for my '12 Frontier. Total cost of materials is $80 and it can be removed from the bed in 20 minutes. It took about 4 hours to build, but I was taking my time.
I am 6'4" and 185lbs, the platform does not sag and I can close the tailgate and sleep at a slight angle. I will be heading up to Montana in a week and will be using this up there. I'll give a report when I am back.
I used three 2x6's and on 2x4 with a 1x4 riser underneath. The riser was used so I could slide milk crates underneath the platform.
The truck bed has indentations for a 2x6 to rest across so I did not need to drill into my bed or build lower supports.
I used a 2x4 closest to the cab because I needed clearance to get past the tiedowns. I had to cut a little bit off the 2x4 to clear the bolts.
The remainder of my 1x4 was used as a guide for the milk crates, so they won't slide around the bed.
The plywood had to be cut into two pieces.
Notches near the tailgate.
Carpeted.
Complete with my Softopper.
stioc
That's a nifty setup, good job.
One of the setups I saw and really liked in a pickup was two storage cabinets on the sides of the bed rails with an open center. These carpeted cabinets also served as a seating platform. Then the tops of the cabinets would fold out (piano hinge style) into the open center space to form a large flat bed surface. Not unlike a camper shell setup actually.
Babbert
