$1200 | Custom Aluminum Roof Rack, 10’9” x 7’3” x 4"
natenatenate
Hey friends! Located in Jacksonville, FL. I'd figure out shipping or delivery if we had to.
I have a custom aluminum roof rack that was fabricated by a welding contractor in Bellingham, WA. The ends are capped off. Welds are tight and clean. I've been using it for just under a year. Dimensions are as stated in the title, 10’9” x 7’3” x 4".
There are four mounting locations with two holes each already drilled into the rack. It would be fairly easy to cap these if you wanted to create a better mounting position for your rig. The cross beams were welded at the right distance for most car top carriers. I've also hauled kayaks, canoes, and surfboards up top. I intentionally had it made wider so that I could mount removable surfboard/SUP racks on the sides.
I'd guess this would be a good fit for an ambulance, bus, custom tow-behind, or an old school truck bed camper.
I'd include the solar panels for an additional $200.
I want this gone! Make me an offer!
