Just wondering if this will work as I'm not the most savvy with 12v solutions:
I have an Antec Big Boy 200mm computer cooling fan - http://www.amazon.com/Antec-Big-Boy-200-Computer/dp/B000V6FKGM
It is 3 speeds via a VERY tiny 3-position switch that hangs off the side (the whole switch unit is about the size of my pinky nail). The specs can be found here and it draws 0.08A, 0.17A and .3A at it's respective L,M,H settings:
http://www.antec.com/pdf/flyers/BIgBoy_sellsheet.pdf
Here is my question - Can I keep the fan switch on Hi and instead use a 12v dimmer switch for LED lighting to control speed and on/off?
I'm looking at this dimmer switch: http://www.amazon.com/Inline-Dimmer-LED-Strips-Ledwholesalers/dp/B004T9ITQ0/ref=reg_hu-rd_add_1_dp
It handles up to 2A and would be far easier and more durable to use than the tiny switch on the fan.
Just trying to come up with a reliable, easy to use solution for some fans in my van.
Thanks!
Thanks!
