12V X10? Wireless Light Control
dzzz
How can I do home automation in a camper? I will wire all the basic lights in a traditional manner. But for the rest of the stuff I would like a flexible, easily changeable system.
I know the newer protocols include wireless, but I haven't seem mobile devices.
spencyg
This Space For Rent
The whole carputer scene has got to have something by now. Probably a bluetooth-enabled control would be easiest to implement. You could also get a cheap PLC and use the plug-in modules to modify your inputs (remote) and outputs (light switches). Could be a cool project, but at the end of the day it would be far more complexity than you need while...camping...enjoying the great outdoors....and all that.
Old_FJ_Guy
Check out the www.x10.com website. They are first rate for home automation and may have some ideas for you in your applications. I have used them and they are reasonable, service oriented, and reasonably priced.
LandCruiserPhil
I agree X-10 is a great way to get into home automation and can be very powerful at a good price But will not work in this application. X-10 addresses through power line carrier and requires 110v true sign wave to operate.
dzzz
Z-wave is wireless. There is a way I could use that system with relays. I couldn't find a stand alone 12v wire in module. But a manufacturer would not have much difficulty making these as z-wave boards are inexpensive.
From what I found out so far, with z-wave I would run Cat 5 from a signaling device to a relay at each light. The voltage over cat 5 would trip a relay for on-off. With that in place I can control the light from many locations, or programatically.
This saves me from wiring four way switches. and allows these lights to be integrated into my security system. I was going to build a little low power always on computer anyways. I will include a web server and wifi that would allow me to connect with the vehicle.
HenryJ
S-10CREWCAB.COM - Wireless control lighting
Might be too simple for what you want, but might give you some ideas.
Plasma LED high power remote switcher
I use them for my Cargo box lights and cradle mounted winch lights. They have been doning a good job.
HenryJ
Just a little update.
The Optronics HyperX wireless light control that I had been using was very good. Sadly I let the remote control go with my old truck. That means replacement was needed. Sadly Optronics control seems to have been discontinued.
I tried a couple of the cheap ebay wireless controls Like I posted above and could not get control of the relay bounce. They just did not work!
Enter CYRON Lighting products
I found mine through Amazon for $34 delivered [ame=http://www.amazon.com/CYRON-LIGHTING-WIRELESS-REMOTE-RC2-12/dp/B0031794IS/ref=sr_1_1?ie=UTF8&qid=1289605409&sr=8-1]CYRON LIGHTING WIRELESS REMOTE 12VDC 20A RC2-12[/ame]
This unit is rated for 20A which should be more than enough for my two 35W HID offroad lights.
They work great so far.
KurtActual
