How to wire two switches for one light?
ZJARCHER
Ive been trying to figure this out on my own, but not much of a wiring guru.
How do I wire two switches for one light? My idea is to have one switch in cab and one in-bed for a rear facing led light that ill have on a "swivel"... can anyone whip together a diagram for the wiring newb?
Thanks in advance!
You'll need two SPDT switches, here's a diagram:
Thank you all!
Im assuming they make SPDT switches that are more auto-oriented, not home/RV?
Just ordered that book as well!
Thanks!
One more question... should I "combine" to one relay or use individual relays, per switch? Dumb question, but until that book gets here, you guys are my best resource haha
I used the same set-up for a rear work light.
Ran power from the battery to the first three way switch in the dash, continued the run up the a-pillar and behind the head liner.
The powder then enters the rear door where there is a switch mounted on the inside, in the door panel. After the second switch I ran the wire through the relay provided by the light manufacturer. Finally, the wire pops out the rear of the door and is hooked up to the lamp. It works a treat.
Good Luck.
I didn't do a very good job of documenting the wiring of this project, but here is a link...
http://www.expeditionportal.com/forum/threads/127342-Telescoping-rear-light
mbobhat
