2014 EarthCruiser for sale
bobar
Adventurer/EarthCruiser
2014 EarthCruiser for sale -- SOLD ON JANUARY 6, 2015
• Excellent condition, like new and lovingly cared for
• Standard features include:
o Two 125 watt Solbian photovoltaic panels
o Two 270 Ahr MasterVolt house batteries
o Cab has a large custom center console
o Very comfortable and heated leather seats
o Two burner Webasto ceramic diesel-fired cooktop
o Webasto diesel-fired Dual Top for heat and hot water
o 12 VDC stainless steel refrigerator/freezer (works out of level)
o 2000 watt Xantrex PROsine pure sine wave inverter/charger
o Numerous 12 VDC, 120 VAC, and USB receptacles
o Seagull IV X-1 water filtration system – can safely pump water from lakes and streams to produce drinking water
o Very large storage lockers outside
o Ample inside storage drawers and under seat storage
o Fresh water capacity = 61 gallons in two tanks, one inside and one outside that is heat traced
o 23 gallon grey water tank
o Firm foam mattress double bed
o Dimmable LED lighting throughout
o Inside and outside showers
o Thetford cassette toilet
o On-board air compressor
o Back-up camera
o And much more… see www.earthcruiser.com
o Note that a generator and propane are not needed with EarthCruiser's design – a major benefit because of reduced complexity, greater flexibility and reliability, greater safety, and less noise!
• Includes these extra optional equipment supplied by Earthcruiser:
o 700 watt microwave oven – ceiling mounted
o Full Dynamat cab insulation
o 2 safes
o LED driving light on bull bar
o Extra 38 gallon diesel tank, for a total of 71 gallons including stock tank
o Warn 16.5ti winch rated at 16,500 lbs
o Limited slip differential on front (LSD standard on rear)
• Includes a complete Fuso Factor Service Manual on a CD
• GVWR 14,050 lbs.; fully loaded weighs about 12,500 lbs.
• GCWR 21,765 lbs.; hitch receiver included; never used for towing
• 13,700 miles on the odometer
• (bike and rack in photos not included)
• Asking $185,000
Can be seen at EarthCruiser located in Bend, Oregon – a beautiful destination for outdoor enthusiasts.
Howard70
Great Truck
I've seen this EarthCruiser. It is in fantastic shape and maintained like new. If you're in the market you should take a look at it - I doubt another pre-owned left-hand EC will show up for awhile.
Howard
bobar
Yes, EarthCruiser has this as an option and it can be retrofitted to our EC if desired.
bobar
EarthCruiser sold
Our EarthCruiser was sold on January 6, 2015. Thank you all for your interest!
WonaWarrior
