My Disco II Build
MStudt
Almost four months after having the Rover delivered to Oregon I was able to start working on it. I've been spending so much time remodeling our house since buying it in October that I haven't spent a single minute on the Rover until this past weekend.
Most of you know about the ongoing issues around the high temps, and the multiple things we've tried to fix it. After replacing the t-stat 3 times, and Airlifting the cooling system with no success we moved on. This weekend I was able to pull all the original tubing off the rover, and removed the OEM fan. I was able to mock up all the new tubing with the added t-stat housing. I also added an aluminum body before the t-stat that holds the sending unit for an addition temp gauge, peck cock valve, and sight glass. I still need to cut the upper fan shroud, modify the new t-stat, and put everything back together. The goal is to have it up and running by the end of the week, and license it in Oregon next week.
Out with the old
In with the new
I also have a bunch of other items to take care of due to this sitting for the last couple years. Both batteries are completely dead, and need to be exchanged under warranty. I need to redo some of the wiring, and install some items that were removed to install in our 4runner. I also plan on adding a solar panel to help with charging the battery since this won't be driven very much.
Mike
WonaWarrior
