BOPOH
Hey voron, how did you get the bolt off from the alternator pulley?
My alternator pulley was barely moving, bearing on the shaft was completely stuck. I used impact wrench, but i believe there is a way fix it in place, because when you put it back you have to torque it pretty high.
I believe according to manual you should take the back part off first, then place it in vice and unscrew the nut - same in reverse to install
