M1102 expedition trailer build
sgthawk
Im back. due to shoulder surgery I haven't been able to do much in the past 5 months other than collect parts. Starting next week here is the list of the next mods on the M1102 trailer.
1. I like the all tan look of the trailer but its missing something - Oh yes an American Army Star on both sides in black.
2. Solar panel up on top with tilt adjustable bracket.
3. 1500W inverter with remote on/off button
4. Propane water tank, Hoffman 24" x 16" x 6" industrial control panel with key to secure it in, water pump, water lines and 20 gal tank. Inlet and outlet stainless steels ports just not sure where to install them yet.
5. Purchased foldable kitchen table with sink and installed quick disconnects to hook up water line.
6. AMP Meter to check current load draw.
7. Wire up cigaret port inside trailer with USB port. I will be using this port to provide power to a 12VDC TF 51 AC/DC - Portable Fridge/Freezer.
if anyone is looking for a fridge contact the guys over at truckfridge. If you order the FT51 fridge use coupon code "Toyota" and pay $449.00 shipped with not tax.
sgthawk
Made some progress today. I was able to remove one of the propane tank brackets to make way for the hot water heater metal storage box. I lucked out, due to that I didn't measure the space before I purchased the box and it fit like a glove between the frame rail and roof rack. 20170528_190826.jpg
sgthawk
I also figured out where to install the solar panel and roof entry box. I just need to complete the installation and wiring.
sgthawk
Today I was able to mount the inverter and solar controller as well as the water inlet and outlet. Last item of the day was the Army star decal.
sgthawk
I spent this weekend Installing the water tank, pump, hoses and wiring for the pump. I used an old ATV basket to support the tank and picked up some adjustable double end eye bolts to secure the basket.
sgthawk
Pictures of setup the springCC226E70-0453-4957-B294-7A63E599BBDD.jpeg12660BF1-63CC-4924-92F7-D06E0F0B31A7.jpeg3E7BE1E2-CF16-42B0-B7C9-E8DCC90F1CE3.jpeg
Flakchaser
I have been looking for ideas for my own M1101 for more than a year, your rig stands out above the others....finally ran across this thread by accident today! Great job!
sgthawk
Thanks. Post a link to your build or share some pictures of your progress.
Jarred
I removed the covers from the black-out lights, installed a regular white bulb, and wired the black-out light circuit into the reverse connection of the hitch harness.
Do can you share some pics and let me know the bulb p/n? I'm looking to do this on my 1102.
WonaWarrior
