Thread: 20lb Powertank - Where to fill around Prescott Valley, AZ?
  1. #1
    Join Date
    Apr 2007
    Location
    Prescott Valley, AZ
    Posts
    297
    Question 20lb Powertank - Where to fill around Prescott Valley, AZ?
    So my 20lb powertank came in on Friday.
    Where do the Northern AZ guys bring their tanks to be filled up here?
    The place I bought my welding equipment said "We dont fill them here, leave your tank with us...we'll send it down to be filled in Phoenix and you can rent an exchange tank.....yours should be back up here in about a week"
    I'm not too keen on sending a $500 shiny bottle off to some tank yard somewhere to hope I ever see it again....
    Almost every number I can find on Yellowpages.com for a Fire Extinguisher shop or Paintball shop seems to be disconnected...
    Can someone suggest a place that still exists?
  2. #2
    Join Date
    Feb 2006
    Location
    The Dust Bowl (AKA - Chino Valley, AZ.)
    Posts
    3,819
    Hey Cody,
    I don't know of any up here - that's why I used a standard 20Lb CO2 tank. It was a straight up swap at Yavapai Welding - the old empty tank and $18.00 for a full one.
    Mark
    I don't know what to say, but God Bless America.
  3. #3
    Join Date
    Oct 2007
    Location
    Tooele Utah
    Posts
    157
    Try a paintball place.
  4. #4
    Join Date
    Apr 2007
    Location
    Prescott Valley, AZ
    Posts
    297
    So far.....most numbers I find are disconnected relating to paintball, fire extinguisher service, or specialty gases.
    The paintball places I have found do not do higher than 20 OUNCE tanks...and they couldn't recommend anyone.
    The Coca-Cola bottling place doesnt seem to be open on the weekends....so I'll try them again on Monday.
    Same thing with Praxair, but from what Ive seen on google searches, they seem to be a tank exchange only place as well....
    D'oh!
  5. #5
    Join Date
    Dec 2006
    Location
    Aledo, Texas
    Posts
    33
    I always take mine to a fire extinguisher service. They always just fill my bottle while I wait. Takes about 10 minutes. There is bound to be one around you somewhere as businesses have to have their extinguishers tested every year or so.
    Aledo, Texas
    -2003 Jeep Wrangler X, 4.5" RE lift, 33" MTR's on 16" Mickey T Classics, Auburn Ected Lockers F&R, Warn X8000i winch, Warn bumpers
    -2006 Land Rover LR3 HSE
    -Cdn M101 Trailer
  6. #6
    Join Date
    Apr 2007
    Location
    Prescott Valley, AZ
    Posts
    297
    I found a place out in Prescott......CINTAS or something out by the airpark.
    $23 to fill up the 20lb tank.
    Now I know CO2 is super cold to be in liquid form in the tank...
    But Powertank raves about their high flow regulator that doesn't freeze up like other regulators....
    I used the tank for a minute to loosen lugnuts and air up (and explode a hole in the sidewall of) a tire on a friend's Sunfire coupe that was flat.
    I noticed the regulator area was all white and frosted up.
    Is that normal....or is this high flow regulator not supposed to have that happen?
  7. #7
    Join Date
    Sep 2006
    Location
    Sunnyvale, CA
    Posts
    1,166
    Mine is not from PowerTank but it frost up after long use. Make sure your friend check tire pressure after a week. My tire fill with CO2 does not hold air long.
    My 06 Tacoma with ATC Bobcat
    Courage is resistance to fear, mastery of fear - not absence of fear. - Mark Twain
  8. #8
    Join Date
    Feb 2006
    Location
    Posts
    3,819
    That's normal for a high flow regulator. Be careful of the first couple feet of hose - it can get pretty brittle when it frosts up.
    When the monsoon season starts and the humidity is higher, I've had the regulator turn into a solid block of white frost.
  9. #9
    Join Date
    May 2007
    Location
    Vista, North SD county, CA
    Posts
    577
    By freezing up, they mean that the internals of the regulator might jam if they weren't designed well for getting cold. That could cut the flow, or allow the pressure to go too high on the output - either would be bad.
    There's no way to avoid the outside of the mechanism getting frosty - the CO2 liquid inside is at room temperature (after it's been sitting for long enough), and physics demands the temp of the output gas goes down proportionate to the pressure drop. (PV=nRT)
    A high flow regulator lets more CO2 flow out in a given time, so it absorbs more heat (generates more "cold" is another way to look at it) than a lower flow regulator, so it might frost up more acutely. But the critical thing is that the internals don't jam from the cold. You can ignore external frost, except for risk to the hose, as crawler#976 said.
    Bill - K7WCC - 2004 GMC Envoy
    Build: http://forums.offroadtb.com/viewtopic.php?f=25&t=202
  10. #10
    Join Date
    Jul 2006
    Location
    Forest Falls, CA
    Posts
    8,488
    Yep, when im draining my tank like a madman with air tools my Powertank gets frosty too. No big deal. Like Roadie said, they're talking about the internals freezing up.
    Dave & Yoshi
    The Adventure Duo
    2003 Sportsmobile EB 7.3 PSD
    1997 Landcruiser 80 Series Collectors Edition
    2005 Suzuki DRZ400s
    Tread Lightly! Trainer | Manufacturer of the Trasharoo
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
