Page 1 of 5 123 ... LastLast
Thread: Agile RIP is unavailable - what are my alternatives?
  1. #1
    Default Agile RIP is unavailable - what are my alternatives?
    After 6 months and dozens of phone calls and emails to Ramsey without a single response I've decided to give up on trying to get an agile RIP for my quigley van. I don't know if it's just horrible customer service or other problems, but the bottom line is that unless you've got the time to physically drive to his shop you've got zero chance of buying his RIP online.
    So the question now is: What's the second best alternative?
    Bilstein shocks?
    Foxx shocks (without the Ramsey revalving)?
    New/releafed springs?
    airbags?
    anti-sway bar?
    steering stabilizer?
    My primary goal is improved ride and handling on the pavement and moderate dirt roads. Recommendations?
  2. #2
    Join Date
    Jan 2007
    Location
    AVL, NC
    Posts
    6,211
    Start with some Bilsteins direct replacements or Fox without the custom valving. You have a Quigley?
    Chris Steuber
    02 E350 7.3 V4
    05 E350 6.8 V7
    90 Taurus SHO
    17 Focus RS
    49 CJ2A
    16 T350 3.7
    www.ujointoffroad.com
    4x4 Van Conversions
  3. #3
    Default stock quigley
    Yes, I've got a stock quigley E350.
  4. #4
    Join Date
    Jan 2007
    Location
    AVL, NC
    Posts
    6,211
    Gotcha. get the specs/part #s from Quigley for your shocks and just get OE replacements. May not be as perfect as the RiP kit but you'll definitely notice a difference!
    Chris Steuber
    02 E350 7.3 V4
    05 E350 6.8 V7
    90 Taurus SHO
    17 Focus RS
    49 CJ2A
    16 T350 3.7
    4x4 Van Conversions
  5. #5
    Default Thanks Chris!
    Thanks Chris!
  6. #6
    Join Date
    Feb 2010
    Location
    Montana
    Posts
    56
    I was able to trim my front bumpstops and still have plenty of crossmember clearance. Took off about 1.25" iirc and that made nice difference for free. I still need better shocks but doubling the suspension's uptravel has kept my teeth and spleen intact over large bumps.
    I simply measured the distance between the bump stop and it's strike point and compared it to the distance between the axle and crossmember. With the shorter bumpstops I still have about .75" crossmember clearance at full bump. Hope this helps
  7. #7
    Join Date
    Mar 2010
    Posts
    138
    I also read that upgrading to the moog coil spring (i think the its part cc880) helps a lot too. It will give it a little lift plus it is a progressive spring. I am going to give it try if the RIP is no longer available.
  8. #8
    Join Date
    Apr 2009
    Location
    Bishop, CA
    Posts
    1,255
    Has anyone found progressive urethane bumpstops for the front of Quigleys?
    Desert Dan
    2008 Quigley Beast with Agile RIP
    2006 Toyota 4-Runner SR 5/OME Suspension GY MTR's
    Jeep TJ Rubicon 2003/3.5" RE SF/Warn Winch 9500TI / BFG KM2's
    Gone - But- Not Forgotten 4x4's
    2006 Hummer H3
    1994 Jeep YJ
    Dodge Ramcharger 4x4 (ACSC-Company Truck)
    Toyota 4x4 Truck(s)
    1970 Jeep CJ-5
    1962 Willys Wagon
  9. #9
    Join Date
    Apr 2012
    Location
    WESTERN STATES
    Posts
    5
    I was interested in the Agile kit also, sorry to hear theres no response. I know the Bilsteins are a good shock for the quigleys but Im leaning toward the fox shocks as they are great on a couple other vehicles I have. If they're no longer supplying the kit, hopefully they'll chime in and give a few details on re-valving the shocks and what springs they used so we can do it ourselves. I'm a new quuigley owner and this looked like a great upgrade.
  10. #10
    Join Date
    Nov 2015
    Location
    Orange County, CA
    Posts
    2
    Hey! I have a 2wd sportsmobile that is currently being lifted by Weldtec Designs. The owner is Jeremy and is a straight shooter.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
