The TeraFlex JK rear utility cargo rack provides additional storage options to organize and secure cargo. Taking mounting cues from the Nebo roof rack, the cargo rack also provides universal accessory mounting compatibility. The extruded aluminum rails take advantage of industry standard 10 series T-slot mounting to allow the use of readily available hardware to mount small accessories or recovery equipment.
An optional side panel kit is available separately
Fits Wrangler Unlimited 4-Door models only. ( A 2dr version is in the works)
• Height adjustable to customize for different cargo needs (from cargo floor to bottom of rack on highest setting = 23.625" and on lowest setting = 18.825")
• Sleek low profile aluminum design
• Composite corner assembly support
• Extruded aluminum construction for reduced weight
• UV resistant hard anodizing finish
• T-slot channels on each rail for tie down points & accessory mounting
• 18 ga. stamped steel floor for rigidity and structure
• Floor panels include accessory mounting holes
• Black powder coat floor and side panels to resist abrasion and increase durability
• Load is carried and supported by the factory sport bar
#4820000 $299.99 Natural Aluminum Finish (December 2015)
#4820020 $425.99 Black Finish (January 2016)
https://teraflex.com/shop_items/563ba7c005a25c5bb19c9976
