Page 1 of 3 123 LastLast
Thread: Yet another Suzuki samurai build
  1. #1
    Join Date
    Jul 2015
    Location
    West side of Canada, in the hills and dales
    Posts
    284
    Default Yet another Suzuki samurai build
    Well new to the crew here and not sure if i should start the posting in the Suzuki threads, but as I am gonna drop a Diesel into it soon ill post here.
    started with a rusted out free 1988.5 Sami and go from there
    stock freebiee start point
    Didnt know it but it had a broken leaf in the back.
  2. #2
    Join Date
    Jul 2015
    Location
    Posts
    284
    well while it was apart i decided to go SPring Over Axle to get more clearance . boy was I a newbie to this I thought it all would be easy
    cut the springs loose and began so i had to make new spring cradles new brake lines spacers for the drive line yea sounds easy
  3. #3
    Join Date
    Jul 2015
    Location
    Posts
    284
    well from there it was new shackles to replace the stock ones
    20141220_193214.jpg well crap now i need a Over The Top OTT steering system or a drop pitman arm no pics sorry
    but hey it sat higher now
  4. #4
    Join Date
    Jul 2015
    Location
    Posts
    284
    Now to attack the rust jeez there was a stop sign for the pass floorboard and three types of pop cans for the rear wheel wells . Spray foam was used in other areas
  5. #5
    Join Date
    Jul 2015
    Location
    Posts
    284
    replaced both rockers as they were also toast
    rebuilt floorboards
  6. #6
    Join Date
    Jul 2015
    Location
    Posts
    284
    20150213_102945.jpg so after some paint here it is ill get some more pics posted tomorrow as its time for supper and football
  7. #7
    Join Date
    Jul 2015
    Location
    Posts
    284
    now im working on a few other things like a 1.9 AAZ VW motor diesel It's an all mechanical Diesel that runs well. to get it ready for drop in i am using an ACME ADAPTERS kit but to use it I will have to do some mods to the motor some to make it fit others to make it last heres a pic after I played PIMP MY GLOWPLUGS and the angled flange to allow clearance for my oil filter
    Attached Images Attached Images
  8. #8
    Join Date
    Jul 2015
    Location
    Posts
    284
    then it was onto the nose bump mod . the original AAZ only has a small notch on the crank pulley and its been known to wallow out and then allow the belt to jump. what I did was drill through the pulley and pin it with 3 hardened steel pins although its hard to see on the second pic you can see that I have drilled into the front of the crank about 1/4 inch this is to allow the pins to be positively retained
  9. #9
    Join Date
    Jul 2015
    Location
    Posts
    284
    The motor will require further mods to allow its use but thats as far as I have gotten on that . it seems I have ADHD and WOULD YOU LOOK AT THAT SQUIRREL!!! I have also started in on the mods to the body I will be dropping on . i started with this . although you cant see it had been rolled and sustained damage to the roof and other side rear . im cutting the top down to make it a mini cab pick up style. I will be stretching it aft of the wheels a foot to allow me to use it like a pick up but i will be making hard canopy for it later
  10. #10
    Join Date
    Jul 2015
    Location
    Posts
    284
    as usual the bumpers will be replaced as the stock ones are as effective as tinfoil for a real mounting point so while doing this I have to figure out how to mount my tail lights and I am going Old school and frenching them into the body
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
