Simple Cargo Slide for my Toy Hauler
Rbertalotto
I wanted a way to access "stuff" in the large storage area under the bed. Here is a quick DIY on building a simple cargo slide
You can read all about it on my web site:
www.rvbprecision.com
colorado matt
simple and it works ..... this quote from your link ... "The opposite end has a thick piece of foam rubber that is pushed up against the far bulkhead in the storage area. Once the toggle bolt is deployed, the cargo slide is imovable." ..... I have used this method before to secure items ... piece of foam and some type of latch to hold it as the compressed foam holds the other end tight ..... elegant solution and so simple and cheap .... good job ..... Matt
TNielson-18
