Page 1 of 22 12311 ... LastLast
Thread: Xpedition Camper out of Minnesota
  1. #1
    Hoefler is offline Supporting Sponsor: Haf Xpedition Camper
    Join Date
    Apr 2011
    Location
    St Paul, MN
    Posts
    109
    Default Xpedition Camper out of Minnesota
    All aluminum 1-ton truck mounted off road camper will debut in Flagstaff in May. Designed and built by seasoned industrial engineers using the latest manufacturing techniques. Built with 600 watt solar capability, non propane heat and air, all baltic Birch plywood interior. Body designed with thermal breaks. Interior is of hygenic design and construction. Price point similar to a conventional RV.
    www.xpeditioncamper.com
  2. #2
    Join Date
    Jan 2010
    Location
    Victoria BC
    Posts
    1,368
    Interesting! Can't wait to see it.
    http://totalcomposites.com/ your supplier for European designed fiberglass sandwich panels and accessories.
    https://www.facebook.com/totalcompos...homepage_panel
  3. #3
    Join Date
    Feb 2009
    Posts
    1,211
    Can't wait to see it. These kind of products are desperately needed in the industry.
    1997 Dodge Ram CTD, 5 Speed manual, BD exhaust brake, 5x12 injectors, 4k Gov. springs, Thuren coils, Fox shocks, Stable loads, 99HD steering, Carli end links, Method Race Wheels, 295/70/18 Cooper STTMaxx tires.
    2011 Northstar Adventurer
  4. #4
    Join Date
    Mar 2013
    Location
    NC
    Posts
    4,011
    Cool, looks like a hard sided lifting roof camper? Can't wait to see real pictures!
  5. #5
    Join Date
    Apr 2011
    Location
    St Paul, MN
    Posts
    109
    Pictures coming very soon. First up is the flatbed unit. Its in laser cut and forming right now. Pricing-its coming in and its good. Think Trek bikes in the early 80's-super quality at a price most college kids could afford.
    Pete
  6. #6
    Join Date
    Apr 2011
    Location
    St Paul, MN
    Posts
    109
    Quote Originally Posted by Victorian View Post
    I would like to discuss total composites with you.
    Give shout when able. 651 283 9542
  7. #7
    Join Date
    Aug 2015
    Location
    Excelsior, MN
    Posts
    39
    message sent.
    cant wait to see it.
  8. #8
    Join Date
    Apr 2011
    Location
    St Paul, MN
    Posts
    109
    Pile of laser cut parts starts to take shape.
    Pete
  9. #9
    Join Date
    Feb 2009
    Posts
    1,211
    Will be following.
  10. #10
    Join Date
    Apr 2011
    Location
    St Paul, MN
    Posts
    109
    20160322_112126_resized copy.jpgAttachment 336143Did an initial testing of our three point sub frame. Looks as though the truck frame can flex greatly without any flex making it to sub frame. The rear pivot mount is secured to clip angles that bolt through frame. Some pivoting is noted here at full deflection. This is critical to reduce the chance of binding original frame and allowing its full free movement. The main pivot allows for up to 10 degrees of flex either way. The clip angle mount appears to allow some movement as well. Note how the front is secured-bolts over springs that screw into existing frame drilled and tapped holes. We did not notice much compression of these springs at full flex.
    At this point of full flex, the front wheel of truck was just starting to come off floor.
    We did observe clearance at every fixed object on truck frame at full flex. Looks like we have a nice functioning sub frame at an economical cost.
    Note the clips that extend beyond sub frame-these pick up mount spots on camper shell. More to come.
    Pete
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
