LR4 Hidden Winch: HF DIY Install
Bama4door
**Update 6/16 Video Added**
This past weekend, me and a buddy went up to Land Between the Lakes in KY for a long weekend. There are tons and tons of trails, most are pretty basic. There are lots of big mud holes that are dug out from SxS and 4 wheelers, but most bad places have bypasses to go around. My buddy was leading and we came across what seemed to be a large mudhole, but it had a bypass which he decided to take. Turns out, the bypass was worse than the mudhole and he suck instantly. Lucky for me, I got to try out my new HF winch mount plate I put in and the Badlands 12k winch. I was able to pull him out with no drama and everything functioned as it should. Here's a couple videos of it in action:
I've seen the few posts and pictures MrWesson has around here of his LR3 with a Harbor Freight Winch Mount and 9k winch. I decided to try it out and take some pictures along the way to help some guys here, if possible.
Obviously, you can find a few different companies who make Hidden Winch mounts for the LR3/4, but most are upward of $600-$1200, not including the price of the winch. The HF Universal Mount was $49, plus you can find 20% off coupons online or at the store.
So I started with taking the front bumper off. It's pretty straight forward: take headlights out, remove grill, remove 4 screws on the top of the bumper, remove 4 screws on the bottom of the bumper that go into the frame, remove front fender flares (2 plastic rivets to remove in the rear, 2 phillips head screws to remove in the front, then gently pull off). Once you have the flares off, you will see a 1 shiny hex head bolt holding the bumper in on each side, remove those. Next remove wiring harnesses (2) for fog lights and parking sensors located behind the passenger side headlight. Then gently remove the (2) rubber lines that connect from the washer fluid bottle to the sprayers in the front bumper. After the bumper is off, it will look like this:
You will see the stock steel bumper exposed now. Before you start unbolting it, slide the air valve block up and out (passenger side), then take out the 2 small 10mm bolts that secure the bumper to the washer bottle. Next you will remove the (8) bolts that hold the stock steel bumper in place (4 per side). It will now look like so:
Take note of the plastic square that is surrounding the radiotor below the middle crossmember. I cut out most all of this plastic as it will interfere with the Winch Mount. Now that the plastic is cut out, it's time to drill out the 4 lower holes that the stock steel bumper bolted to. I drilled out the holes to 1/2" to use with my grade 8 hardware. Below you will see the bottom 2 holes drilled out compared to the stock holes above.
Once you start drilling deep enough into the holes, the captive (see pic below) nut will pop out that the stock bolts were screwed/threaded into. Make sure you remove all 4 of the nuts before moving on.
Now it's time to pull out the HF Winch Mount and start drilling holes. If this is going on an LR4, there is a black AC canister on the left side with 2 tubes coming out of it. You will need to mock up the winch mount and notch the plate where it intersects with the tubes. I out out basically a 1x1" on the top of the plate. I've circled the canister below and you can somewhat see the notch I made. Sorry I don't have any better pics of this process, but it will make more sense once you put the winch mount up there and play around with it.
I don't think this step is required on the LR3, but someone chime in if I'm wrong.
Now you can start on drilling the HF winch mount. You'll have to take some basic measurements here of the (4) stock bolt holes you've drilled out to 1/2" on the LR3/4 and make sure that lines up with the mount. Pretty self explanatory, but just be sure to measure 3 times and drill once. You can see how it looks mounted up in the pic above.
I decided to go with a HF 12k winch I got on sale for $319. The nice thing is about these are the solenoid boxes are easy to remove and place elsewhere (which will be necessary). Winch mounted below.
I ended up mounting the solenoid box to the left of the stock horns and then ran the wires directly below to the winch and then up to the battery. I also extended the wiring for the winch controller plug that was mounted on the side of the solenoid box. You can see the tubing going out of the box in the pic below. I'm eventually going to mount the controller wiring plug somewhere discreet and easy to access. I also took the time to place a bead of silicone around the solenoid box so keep water out (cheap winch, just wanted extra insurance).
Now that everything is mounted and wired up, time to put the bumper back on. You're going to have to test fit the bumper a lot of times and start cutting out a lot of the stock plastic behind the bumper. I didn't get any pics of this because it was basically trial and error. Just start small and work on sections and test fit until you can fit the bumper easily. It will definitely be a tight fit. Reassemble the bumper per the instructions above in reverse order.
Once you have the bumper mounted, it's time to mount the fairlead and cut the hole for the winch line. I did my best at eye balling everything and trying to measure and it turned out well. I don't really have a lot of instructions on this, just be careful and again start small. Drill the 2 holes for the fairlead bolts first (they will be 10" apart) and make sure they look center to the bumper. Then take your grinder and cut out a square for the winch line.
Once you have the holes drilled for the fairlead bolts and the square section cut out of the bumper for the winch line. Time to mock up the fairlead. There is going to be about a 3" gap between the HF winch plate holes for the fairlead to the stock bumper. I used 4" long 1/2 bolts along with a ~3" piece of square tubing I got to act as a spacer between the winch mount and the bumper. See pics below for square tubing I used from Ace Hardware.
If y'all have any questions, feel free to ask below. I can also try and take any additional pics too.
Final product:
spikemd
Great writeup. I am sure others will find this very useful and save thousands. My only concern is whether those plates you attached the winch mount are strong enough for the winch. They kinda look like crush cans to absorb energy in the event of a front end collision. If that is the case, then you should investigate how to attach the plate directly to the frame.
Bama4door
I've thought the same thing. I'm going to test it out a few times and check the integrity after a few uses. I'd like to eventually weld some additional plate to the mount and attach to the frame and gusset a few spots. I'll keep this updated as I use it.
MrWesson
I mounted mine differently and also question how strong that will be(highly doubt it's strong enough). I hope my explanation didn't lead you in this direction.
I edited your pictures to show where I drilled/mounted. PLEASE KEEP IN MIND THESE ARE ROUGHLY WHERE I MOUNTED.
Good news is that you should be able to drill 2 more holes through the mount and through the LR3 frame and make it strong.
https://www.youtube.com/watch?v=md8Sz60eyU8
Bama4door
All of the hidden winch mounts from companies designed for the LR3/4 use the same existing holes I've used, so I'd imagine it's got to be pretty strong. I have not utilized all 8 holes, but would like to eventually.
Like I said, I'm going to test it a few times and will report back.
ar4me
Were you able to retain the front parking sensors? With the OEM Warn winch you lose front parking sensors... Not a big concern, I didn't care, but could be a benefit to some.
bentonrover
Awsome write up and thanks. Driveway looks like mine. I even have a FJ62 parked next to the LR3 lol. About how long did this take? Sunday afternoon type job?
MrWesson
Yes, all hidden winch mounts use those holes, so I would have to assume they are strong enough as well. I installed a Front Runner hidden winch mount in mine and did it basically the same way, but I cut the two end parts off my bumper and reattached them. So, basically, I just cut the middle out of the bumper. Would it hold up in a crash? I have no idea, but it makes me feel a little better. ;). Thanks for the photos. I'm sure it will help others. I can try to post the Front Runner instructions as well if I can find them. It wasn't much... Just a bunch of photos I think.
If yours works then its clearly the way to go as my method was more work(drilling the frame).. Hope it works out because i'm thinking of redoing mine a bit differently. The long grade 8 bolts that run to the fairlead take tons of force and i'd like them to be shorter.
perkj
How confident are you that a HF winch is actually going to come thru for you when you need it? The rule of thumb I've heard time and time again is that you NEVER skimp out on recovery equipment.
Bama4door
Thanks man! Hope it can help. It took me a solid 6-8 hours. I've got a company car as well, so I worked on it throughout the week after work. Love my 62 also!
Not extremely confident, but I don't feel it's necessary to have a $1200 winch on my LR4 either. I use my fj62 for the extreme stuff and have a Warn winch on there. I use my LR4 more expedition driving and not anything too crazy as it's mainly my DD.
Also I'm going to post up some pictures of the spacers I used for the fairlead later today, so stay tuned.
perkj
ah ok, makes sense for your situation. Others who are reading this thread should be sure that the winch they get meets its intended use case.
I used a Smittybilt budget winch for years on my Jk.... I ordered another tonight and will do the install as seen above for the LR3. Performance of the winch is ample. Hell, we arent crossing the Darien Gap:xxrotflma
Joseph McCormack
