DIY aluminium roof rack? sure why not :D
paranoid56
so i was looking at the front runner and some others that are alu, but nobody makes one for a first gen tacoma double cab.
so figured why not make one. Something thats easy to build and bolts together.
parts list
  • 5" alu stock 1/4" thick (aprox 10ft long)
  • screws
  • 80/20 Inc T-Slot 1.5 x .75 Aluminum Extrusion 15 Series 1575 x 42 Long B1-5
After looking at others i went to the metal shop and picked up some 5" 1/4"thick flat bar.
cut it at 4ft and traced the outline of the roof contour on it. This is where it gets fun :D I cut the alu to get it close to the shape, around 1/8" to the line. next i made up a wood template that was perfect and smooth. bolted the two together and used a flush cut bit on my table router and make two copys on the alu.
gSHBbIQmMSy8DU80NxwbnkpqD5KCKSiJU3NT53Fhwu0V2e94m_-QZ7XrDmmtbN3vH38-OdhE1eTUQ1FRbI4RELY0rilK0ECICt95n5zgylPU3K2jn-nQ_hHtfhWtQMiVLSl8bfrOOx6RV8p2PguQ3KPCpeTRPome-nx9dSszR7Vv7ddDEeZm31vddHWBD5p0i4IRVezD5wb1FsT3BCV_oMvoJOGGk1vcC86PqdW-c0cD8x6QhWCXwSROxc5wqmf9VhlSEOOK-VDMcPPU6kuKO6uxR_HHm3w5QGmRUz5rM178WiQbTitsPmZZtKpbL7KK3imm7J4dgSHbnOgKgo9kQ5NdVHCtqyz4Qhh6C88NEmCzXvBzEKgne53x-7Gj7EkCLoJVqi5WHwcBlj9dS_4vyvxAY_yYg7Q6l9CUl2gSrP2JUSBnQi68J6E1V1stAn6ikZXPh6yXB6kRBdQcj3v2jcz15KjLgjOU5Och6NjEmC1BOeJM30AybNabSf5BWNbvYW5fURUYYNr6WxAeTTDeEZLv5UyWIySW8MEXGK56-hfsF3IDV_w9S4UD7Cjpky8gzGlC3xOM2q9lQivRfnIjOd4dN_Y=w582-h775-no
if you try this, make sure to wear good eye and hearing protection as its LOUD.
T1NBPa_kxgPPzTiRomC1Vc9Wey2KOgG1Ulv9BbkBGBvXwDbb1gEsFIvcdOEgAguEdQ_Y-xJHtLEGnd4T5AGMaLZSmd00DkLrcPGVD4Uxm-sajOUgE1cPvCH9Y3GsIljmy2Dbrmzfw3EAcH5nfjm8MN77otEPDM5JegQ_3ioRbJksIDhgEJtq7iWy30lltIpCURrgSab579y4mC8565Px_ciW0Dzj-aeBcdrZqi45JRpjopuEr95m8rMDMNfQgmAB_yDMSKA80TBG4_vGgzcDbLtHh76OM7Z3XOAwP8941ZchaizWMOsC1F2fk5-T54FosLVIpKy0FdnCxzlBdXRk4eY69i7ee5VToMuWa1C6bofZ8xgwzcLabFQASuwJ72Qb_7wTaBgRDeKkEX7Hn8L5pEb336JGslML1YvxPzBpZ7WO_wJd4juskCn6x3odND75Nr0MNQfBN_Uo9kzaPp_p5SBVJI9nJSz00esxIaswc0uluwftzM4Tp7SFrqIZHFigIq1F2ygBsJBq5jlBw7xi6L-5UATSRawcYPjjNVJDM6hKJkNimojqMpgBvbGTWIfxIWOtjXp0FrjcbmbxyvNjR9Kif-I=w582-h775-no
for the cross bars I am using 8020. I only had 2 so waiting for more to show up. have 6 bars coming for 60ish shipped.
seems to look good so far.
VLh1p3mkj750ObArTZ0kRIQGaZcjHRpBeeyTWJWrEW6f9X2kpuJu4t66qLf9LRqGX4awmlDT51yQ3MBp4PtgDl8EHFTMKHBs-2lLTp0TStVx0d3PrY5fokjM8EAPyIqGyNnCH7S_LjV-8z8lX0yzblSSLw8BENOJefTJTtyU3ZG8nnSQqDU3ct00lwq8BQEXIe0fMDfNVk-IXr-_7OWP_6bFUw-lx-jKdH8jNMuJO-_xyGSLgBHiH7fJJCWkmL_3VCx3izrOonea3nYKlZ56d_0-fI5z3DIXDtcfdhveKrPvZCse7KfWZb1VbzQX_0qoYMB-c6mhiR0gzhzBeedM1Fqx-RA8q814c3fQtSZ3tP3j764VknBTs4CC6kukQ6KDsisJoCEQnpyS77abonM-Oy4UshOKpU0Nm073NVvzGCjhEHA-W_w4_YofG89OZ97PjfCmp3spT_FXEt53ih-zxYeGLEOT9KemXdK9NcOug-Rp2SQwbdcWXaNc92yp1VpjmuxQ5Bi2VDSeZI6QlbTmu_5aizG37Jya-cS4ClCSyTX0ctcM_u5rS93XAum_tF5BGeTowx0mnpthGxtKS7JOF48GCng=w1034-h775-no
next up was making some feet to mount to the truck.
need to find some shorter bolts, but these will work for testing.
yXTWi5Pf8DZ6meJaOvzEm6K89WHNAd-XKyef2X50xym8lWiDnuA5UOPrtG6S6FHcxYnpRmpz9tDjE7rrV_V_CCpTifs6LSjXDsgkfdXiAUOqwmZOckpSsXV0ZAfnzeZKzSgvIstyjka0S1nufH8-aeASIiJeBWVrqwjD14J5AT0RpkWmjD-5lUMuZBV9yWqpyxbu_xDYqA8PKG4MhUdkDg8QSP8_PBxWweecLsrp25IiUQ2em3n9RujSMYXyX0HtXgFANoa-GDKPDRmoko856jxLVKq2ap71i9DSsllWC-Y48X7Llt5a79A2NwKt-1pEc6Ut0XCU_KFOMvTzRz8q2A0WKdgMyImUIij1nEL3gW0nJsCpwB-7FcOOuxkVoN6qvnTFBUXO76MVYXZ_DEou7hvTcYsfi4WNWKB9EWG2tEzNEBaTYK_EZNaKH5n_tR28xASDpLbMsTTm91I68MM9YzejI0z370iDghPzx-eU-nVl_duVkQkH7i4_44B1fg0tRX_uUt5qRU2vFL3_SnwGVq5_Z7cQaxnC0lFgFZOkuJseVM6h9a_T9C9ZqInpFgPixr5hp523isF40OaQpaqKu-kkz8g=w582-h775-no
and the first problem i ran into. totally forgot about the contour of the roof in that direction.
M1eJp_Q9gbqityILgSgMRUqDM9tmviK3qZYHXUYxtdOKQuSciEg7zF-aziBv9xy6CP02bhgQYQP7kiJzj6L2XE7DzDcrvPDKrrX8hC3Q7-ITC9YRgifJf5Th8mmrfQ6_Z4yIk7Q73A1X1L1DBwKBepawPg69WsBC-Uq0LFLVUNje188fq7KF1Iav3RvRb1FzX_DqeiUgViPN10rvUXPo_zlF4vFf_zZDwmhzC-bpPcRVTkx93icMwA_Ym6JNiZCxz9qBSvETW3Hn11JsZO0cytCSkMyUBtaFfsoWyKodeOeCPoxi-yhiA8KQLuGPARS9Uu0SAfgF9FFF6cXcu0dphu7UZ3MWubh29aESMH3q_pmBYxgI0eJYINA2hqlvFaLWFon870Yt-ZBUCLSnn-bxSIQ-P5gxWuKz0c0v07Wrb2a0IwCU2fSj493VBd08ZcvUFhcdQ0Sy7IeqwOhDobDgp1tfBChjKWqTdYewCHoy3WJ4fI7ZorFUjqSz6u80YKLyUs50xaF_sWLGorUhwDH0YIo02FDneSYEweW-AvCmfkyAitkCWkgMBPRsvv4QqUKO6n7ggFF_0IW602ngAWU2hjoGD6g=w1034-h775-no
and here. i think i am going to make some plastic spacers that mimic the roof better.
hSEvTNZ6r3mq1jZHttFHwyBrZb75BKPSEFVHpdgLxNFA7LqX3ewyjpCvOWSPotRxlXHp43lBqdfKBtTETF9fvzu-PM-aFJoBBuFfSOL3OQULHGvuxCdBexUn5Mc_8LgsZNKb2zyTF4f6sItto9ZfSu876NRMIwoTLclOd_9kUYOVv3GwNRqF2JFAziWYt-UQZMHTv8hVfh6qrIuLprwzQETuVa9TGMnLDnKForUE6VzskF9Y2-SgKqxZT4KWCbhN8zVRCSODAeTmRge6u2Zpuqy6TDWaxpJggSw2dsyaay3e2gZHXAUavse5UlRr48mSvppMrIxXpgB5nr8xI9hsiw6NhNsdNCP3ZoycAYnFPXbV5jIJwCGoPa7-s1IlGzucRGfer6xaBjVvLKhu-IFst93DlvZ4Bc-GWIUFFLnrOjmTEqmZ6EcJFCPoWE26pzVzs0OfwVggiK4ty2rvwn_BU1iq1vti_CitRvUyAYE9CNTus_ql6cJMnuEhBnCyHwTNgpdwDkjCW-GKkxphQP-xM7Sxi-UiwW_nv3mDWjTNWEi5Xtoyqam8ygz8dvLnfjCryamypxnqINqsp7fmALIbtgv0uEs=w1034-h775-no
That's pretty nice! I have the same premise for my DIY rack (easy to build and bolts together), but a lot simpler. Just angled aluminium, holes, nuts and bolts. Yours is fancier and sturdier.
yea i kinda wanted to show people that you can build a good looking light weight roof rack for under 150 bucks and made with basic tools that most already own :D
Looks great, I just made one very similar for a sequoia. I cheated and used the CNC though, router was a good idea.
i almost did that but my cnc table is only 2ftx4ft and at the ends it gets iffy. and this being exactly 4ft long i didnt want to chance it lol
Gotcha, ours is 4x4, but the rack ended up being like 7'. I did it in 3 lapped sections, joints are practically unnoticeable. I know what you mean about cutting 48" on a 48" table, gotta be right on!
made up the plastic spacers to match the roof to the rack. I wanted plastic to keep the alu off the paint. also easy to work with :D
I had some HDPE laying around so it worked out perfectly.
JUyqmFBQBAgRrOlKE_67PBsXOiY9OYZ7xLQgj80zdfKnhn9zjyY534n9HXXfH9GMULM5kIuJZcTafKdzbMhFxjitVVngiqUa-EnNus4R62I3ONK5xHPXOnbisWWsCTFr7_9dRNOtv2IF9_18prtMpQ8V6AY4MtCpO0k-HraD4JmZYHMYnTQbrXTbt5r1VmCPJZ4Hf57mrKp4WIWHDrqHsTxpJyaY_TD1h9Le5XkbJQPuOz7S0yqIyVpwv7kdJc6NJQ5fjtL-OqjLEItG8m5M1wrKwTZCe8gDobJN-HKr1u1rFAK7KKZWDwXydbWakJirS-LBljGzw5f3VCKpOAKcuJOuirIVcTwsWhjAe2K59OFiUpbMq4WsgKqIuB3pXFKvQU4EA1AvRpP8Znn9DD5jE-5QWpqyxXfAx3XvfyUZSfrtIbkMEMqNdQW1yK7tkCu_gsYkf3hJG2rVXplJz-59XSof1LMy9IsheAyzEb2T4Ea3At3KWtdDS5cJsHapRcMPAtHAe_XrJNOiXq731U-rpYzbOyeimfpR62zpDEMXpwdbLKXyqdC63RZP6WZgv9VtZ8mbxtGgUk3B0zMZq3a3DM8bj28=w1034-h775-no
close up.
fMbtKY-45qRc_B4YedTe2V_Lp6GtL4cHP6_ZP77QWitinpwTgCedtHB-agEUAQbey3JK5w7GnjJJdFFThzxD4jezuEZgLHoGysYVUt-t3GLN-EsZJPuiMohP58CqHrOiKZd-vKGjDZpDRKEQndzNionlslsuhU2qSu2zi6RfRltSfsKWZDqNED9i_AVjzOVlshV0Z-VXJdhnuIMz1IsG6SjPH-dCKzvuESF47NtPCo6eO8KpOzWbl04359gCIfyUO6Zfaxfb2R-gMU2ifaQmR037QfDL16_Rbbq6ebrvY-j8vNWD2wOs5UaYf1QRhu_80p5tOf4NuOqMCH08gBrMVgdOndqhu7wRDQtBK6Y_ZEkogplJrGaKXC0EodkYn4qbN89xz285aVBFQ8HXmhQK59RTsTdj_pBY19uiu8Y32B3_nOZ0RDAbCdCAk15d55wOggrgMP54VUa6iMzg-SgCg-NgtlKWJ35dW8mvy7GXgXCRjmiqCRoV8zl1-ED3uaBmnc_hORmbPxvOHrGVMGNZIKlafOi7YX3H2WJXW40EeLB54VUB1dn34JVqjj0fiqpCeXx_9xGE3DuAlP8yGLIJYywB09s=w582-h775-no
and i totally cheated making these. i was about to make up a jig to run on the table router, but I looked over at the mill and went to town :lol: this piece is totally doable on making it by hand though.
N3UdR1Wa4xTWO9JUGEeMpQWAanxT5TfoSE1CAzRoJQrXXQE0F68vs36e5R03PBIL1QVKVQmuanfbG7jr9vhDZd2sdeOFi_x0U_Sr4XlJs2axswDCpWEDbtxxg0r1Jj6kXOAJ91PZ6z9j10NTYxTbBju4ZwO_A2F97F2zRCbxlMrQhy--t5fjRt134OMnb_xmUrsKLPEAv1BXrsFGzeA9T5-qXcSI34y0-824CpvSzcZ-SnbHMFG8LCIgE4NnY20saHAF80k9hWMdO1fZlZXVTcxJl5V6XK0QxgJo5hYa3oY_gA-qIuQZn53I5MSP_Mu2MK2qzvAJgbCTvvxWnkMg6V-9ZEIiyNgUWZ5boMCG92deDXT2FWKJmep1Cfgw2X_o9EyL6wBB_M6WcSTu_QHUuu7dmVbv1ocQAlXEW3I1pKtbuvOBv-YVD_aKjG-w5HVfmLXpLdUZoGRwBNZRpJZfocls6r_XnCVLtRUwe0cXhDREeEUHIj-1HBJTiex1-0XLcwCFj7jePUVbq5Trt7K8SlXcTcLKznNHrTyDSmiU5HvznL4uvgkmY0CFx3TZGNiMUfwJu4osB5oj0G_eKwdj5xLMsjw=w1034-h775-no
Bravo boss! Looks great and you might have inspired me to make one myself. Can you post up your source for the crossbars?
the cross bars are 80/20 aluminium. they have a outlet store on ebay that you can pick them up for half cost then locally.
once finished, i would say i have under 150 bucks in materials.
also, nice to see a fellow FJ40 owner :D
Thanks! And long live the 40's!
so drilled some big ol holes in the roof and put in some riv nuts. also smeared a lot of silicone to help with any water issues.
aKCD83aR7kKjnhTNrNU8PLNZFKuTa1HfPbYVWMa8_BKYTAezUwhwQPMKcjUx1BDW0JyPyLpkaS794i5tGXWgie9jV0ckX1b1mP6K7Mwb2rmMWkn396nkxOw51R9qicA3_XYW17CdpbyJGsrzQGVjC7B7dp7mQkEnOuhmVuw1crK4pFf7iCCh1BaKuTXlWhXUTCEBeu6RIYjPWdCtSJ1jKp4vUbU1KoGUHRuZd38p-gD01C593fNEz7fVwqb6AkDtSCGYPnYE-_xuoY-43gQS1E2tsW1tRO9dp_kkgWB2U8Mh8G9kcO-d1snYCtCdiEIeg8mDMVM7QqeZqNSEoxaPwmdl404uhNSMODsUtqlSX2Qr5Aem0936EExLLSyeahL8R2FgEmXkcl3HWwAVPtEJbT2edPZ5mo0ytfHJ8AWyRLht5ptrreWP_i05Yoau2Qubt72SWUdsUXOIYWbnkY0ZcEXC4YjZ58aqMMlzGwGdhFeRetQjyuxEDQQyhvThKTCL5yicRC6o21e1nRWI7PPm5YBhEl3TBtfEUtY_kTufQbkeTQXiVFGZUiKkOBX7x8F1hmonSJXxdht2Jc_HVrIsJXnhT7g=w1034-h775-no
and installed, i think i am going to move the light bar as it kinda looks funky lol
5AHwAhxmGA6jFjZygU-49B79LsK4Ud5CCATNLnihWfJYQI5XbwL0A1pwRlXjzwDXkOAkFmWcfPs-pWYPmYWSw3Jt4Fpye0cZFYhVFTgIlsCj6gNubFuiHqiwOXwvViYZstdhoUpA9tspAhcc5_ec8dpvkoFjI9jyed_M3F49ifr6AhAoTmm6fmxz8YwYQwxTA9t5O52pOc4SeG_eVdYba9DKcNsT4GCFxYp5CHphM7hBYLHg4Y7tWu0AEHU8hjrkDgZ4Xgh9aIDOYRygL5AzPnhJLlcLc3I6q-kVpn_jZ7B9XvplPlz87r4AHAs-nQw1JJDTFZvxeu2k__SPx9aRRaelUF1BCEAkddInNAj0W4L52wC99gdL-_Ly08okb2gpSKXeu-qNXau6AjelftkHl38xw3Y1agbQzsaUABQFXf4Nwfxotz6cG-NbZ-9xu3NSpNWIxOFF7JP6VrOrVX6-L1W54fBDgHqS29vb-CFaoIDCWMdVKo00wAmcveaPyTHh7KCK6NninrBMd0L0swABi3O1Ca90LwTTsCRCOJgKwF8UV0RpRLTcUCXMIjypU0t_0y9e5FyE4wGhDr-ZNDHvl6FEL-I=w1034-h775-no
and another shot, going to make a matching one for the rear.
Uq2tEB81waQBIZ5xoNKN9hBKENIP_5Tpe12XfXmjAxZHzJ4IqtD4arx5KG5cfLjfDITpPoWsiseKwvpCXYsOJiYtV8DUidTk59rNOZkiNnY0taOJnppaokOYxg3mFuOqTMPPkBYBHUwvDzZJ7AN0X-qW9jbmCcZHukGSQsynZvuRIZ9KPtmbpD2lPVvGn5_lhOnx8P8LdPkG0scI5eWb6LFrkDpwSGdpuytqwSmUX1jPsGJhv1jxzjyTPs7fGLxZPpJudpg0aI4PwMO4DPHwO7nO09EGsKu3klBC453hLDGlTBW9IwioT5XVPm4ky0JsRXMxGzYSRtwFyjALUCvj55VkkdDsCT-SMlzXeprK1EEnCBkR8e2SgxG-OJAYALQi3pAixd8Yt9gG71AS78RjQgELy8z6KsLofotdur2q5uUR1_rV_pDvruJ78Z5Ke_TLXr-ifVJlkafBz89530nQfvdDvMvswl8mqrDGanXNw6wXDtPUpc7sOmQ47GzwFzasNRV4RCecgppCKK7sZsiisw5-xCao2LA4jGHsDtDv11ek0Ce_lXIipQeqnCOiFCqvppcUYTN1XF_1ZTGaGBGeVy4CV1I=w1034-h775-no
5mouse
