Utility trailer teardrop/ off roadish camper build
jonesw3
After selling my last trailer, M101a2, I have decided I want a teardrop type camper. I already had a 5x8 big Tex utility trailer so It would be a good base to start. This is going to be a very tight budgeted build. I don't plan on doing anything too rough with it. Just mainly Forrest service roads and backcountry dirt roads. And with football season coming up, prob a lot of tailgating with it.
I started off by doing a spring over axle lift on the trailer to give it a little more ground clearance.
It should be able to clear 31s now which is plenty for my needs.
Alabama Overland
www.alabamaoverland.net
I then started the search for Windows. It took me about a week before I found some the size and price I was looking for.
I went ahead a test fitted the roof vent while I was at.
Alabama Overland
Next I coated all the wood with thompsons waterproofer.
Per the instructions, it's has to sit for at least 30 days before you can prime and paint the wood. So after a long wait, I got to start priming.
Alabama Overland
I applied 4 coats of primer. Then I put 4 coats of kool seal of the top and front slant.
Then I bedlinered the bottom, a little ways up the sides and the rest of the front.
Then I did 4 coats of Valspar durmax paint on the upper part of the sides and the back.
Once that all that dried I was able to permanently install the doors and windows and seal them up good along with the outside trim pieces.
Alabama Overland
That leads us to today, almost 90 days after I started the build. I wasn't feeling the white trim so I decided to paint it black. I think it looks a lot better now.
I started insulating the inside today as well but didn't have much time to get it finished.
He is a shot of the interior before the insulation. ( the cot was in there to get some measurements for the bed platform. But I kinda like having all that extra room so I may just leave the cot in it for now.
Alabama Overland
Very nice build. Some good ideas, can i asl why you decided not to have a rear galley for cooking? Was it due to the side rails and being tough for aide doors?
Sent from my SM-G920V using Tapatalk
OchoSolo
