1 Bored Clerk's DIY Camper
1 Bored Clerk
I'm interested in your prices, specs, etc on your boxes... if you don't mind sharing.
About $1800 for both boxes. Full custom to my specs/dimensions/door design. Three point latches for better security, 90 degree vertical door opening with dual lift struts, matching locks for both boxes, 110 degree seal flanges for better water proofing, bulb seals, .120” wall thickness, all internal latch mechanism covered with aluminum panels to keep stuff inside from fouling latch. Mill finish as I don’t like diamond plate and don’t want to deal with polished finishes. Oh, there is a drain in the bottom of the small box so we can hose out any sand, dirt, mud that may get in there as it will be our ‘locker’ for wetsuits, firewood, otherwise muddy stuff, etc.
1 Bored Clerk
Bunch of work done on the door:
Recess for hinge mount plate
How it fits
Epoxied in place
Same done to the door panel.
Next is to get the door corners cut and test fit the door. Need to check for clearance and proper fit with bulb seal.
jgrillz94
