Page 1 of 7 123 ... LastLast
Thread: A Little Different M416 Trailer Build
  1. #1
    Join Date
    Apr 2016
    Location
    Washington State
    Posts
    53
    Default A Little Different M416 Trailer Build
    I have been wanting an "Off-Road" trailer for some time now. After looking around for a few years I considered a few things...Buying One $$$$$...Making on from scratch-ehhh... Then I came across the M416 military trailers. I liked the look, kind of nostalgic, not too big, floats (lol), and its something I could repurpose. It took quite a long time to find one in good shape under $1000.00.. With diligent searching I finally found one for $600.00. I picked it up, had it sand blasted and found the body and frame was in great shape. I sold all the parts I wasn't going to use and started purchasing upgrade materials...
    I started of by covering the circular rail tubing with square wall tubing. This was a PIA, but worth it since I was planning on placing a lid on top and a flat surface to mate it to would work out a lot better than a round one. I ditched the stock axle and springs for a 4000 pound axles with 6000 pound outers and about 4 inches wider, yeah over kill. the 4000 pound axle tube has wall which should be able to take a heck of a beating if needed. The 6000 pound outers had the bigger hubs which I will need to support 35x12.5 tires. I also started to box in the frame since the original is a 'C' channel frame and I cut out the rear cross member and replaced it with 2x3 wall tubing with a trailer hitch. I built a lid with square tubing and 14 gauge sheetmetal. I am now working on the new tongue which is stretched approximately 34 inches longer than the original tongue (see pic below with old factory tongue as comparison). I don't won't to spoil it, but there is much more to come......
    Attached Images Attached Images
  2. #2
    Join Date
    Apr 2016
    Location
    Washington State
    Posts
    53
    A few more pics of the process
  3. #3
    Join Date
    Apr 2016
    Location
    Washington State
    Posts
    53
    Ordered the 6000 pound Dexter Axle with 3,500 outers. The tube wall is , which should be able to take some good trail hits. Net/net it is 4 inches wider than the m416 axle. The 3,500 outers get me the bigger bearings as well as electric brakes. I know it may be too much overkill but I look at it as insurance.
    Making headway.....
  4. #4
    Join Date
    Jul 2014
    Location
    Montana
    Posts
    20
    Great start. What did you pay for the axle? If you don't mind being asked.
  5. #5
    Join Date
    Apr 2016
    Location
    Washington State
    Posts
    53
    Quote Originally Posted by pierceg View Post
    The bare axle was $431.00.
    With the Springs, Hangers, Brass Bushings, wiring harness 3,500 outers with electric brakes it all totaled up to roughly $820.00...
    I just kept telling myself I only paid $600.00 for the trailer so it made me feel better......
  6. #6
    Join Date
    May 2016
    Posts
    47
    Your price rationalization is on point and your fabricating skills support the plan for your build so why not! Great start, be following this one closely as well.
    2008 Jeep Commander Overland QD II, OME HD suspension, 255 Cooper Discoverer AT3, ARB Simpson III
    2016 Jeep Cherokee KL Trailhawk Bone Stock OEM, ARB Simpson III
    M416 Trailer Work in Progress
  7. #7
    Join Date
    Apr 2016
    Location
    Washington State
    Posts
    53
    Quote Originally Posted by mb1k View Post
    Thank you.. I want to try and keep as much as the original m416 as possible, that is why I boxed in the frame instead of just buying new steel and building a new frame which probably would have been cheaper and definitely easier..
    I won't have time to really do much the next few weeks with the holidays and family in town, so for now that's where it will sit for a few weeks.
    This is what will be towing it http://www.pirate4x4.com/forum/jeep-...-tj-2-5-l.html the trailer will be painted the same color with matching 35's and wheels....
  8. #8
    Join Date
    Apr 2016
    Location
    Washington State
    Posts
    53
    Made a little more headway this weekend.
    I welded on the spring mounts and then reinforced them so they will slide over obstacles a little easier...
    Next up is welding on the spring perches to the axle....
  9. #9
    Join Date
    Apr 2016
    Location
    Washington State
    Posts
    53
    With the holidays I haven't made much more headway.
    A few accessories came in though.
    - Hinges for the lid
    - Lock for the lid
    - 4 interior led lights
    - 6 exterior led lights
    - Upper and lower shock mounts
    - Custom Switch Pod for battery bank on trailer...
    I should be able to make some more headway in the next 2 weeks..
  10. #10
    Join Date
    Apr 2016
    Location
    Washington State
    Posts
    53
    Picked up a few more pieces today:
    Trailer and Jeep wiring.
    I also found a much beefier shackle than what originally came with my spring kit.
    The original kit had 1/4 thick shackles and no grease fitting.
    The new kit has 1/2 thick shackles with grease fittings..
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
