Page 1 of 4 123 ... LastLast
Thread: Volvo TGB 1314 6x6 Expedition Camper
  1. #1
    Join Date
    Mar 2011
    Location
    Denmark
    Posts
    21
    Default Volvo TGB 1314 6x6 Expedition Camper
    Hello
    I bought this Volvo TGB 1314 6x6 almost 5 years ago. but really first got started with the transformation now, from military vehicle to a Expedition Camper! Will try to post some more pictures later on, as build is going forward. Mercedes Benz OM606.910 engine with 6-speed gearbox are 50% ready. And a emty alcove glassfiber body, is ready for the last parts.
    Tom
    Attachment 388107Attachment 388108
    Attached Images Attached Images
  2. #2
    Join Date
    Feb 2011
    Location
    PNW USA
    Posts
    1,597
    Very cool project - interested to see it progress. The challenge on these has been getting enough cooling via the small radiator location - don't go cheap on the radiator is the advise I've heard. You might check out the forum at www.real4x4.com for more Volvo C30X builds and support.
    Welcome too!
  3. #3
    Join Date
    Mar 2011
    Location
    Denmark
    Posts
    21
    Quote Originally Posted by Haf-E View Post
    Welcome too!
    hi Haf-E
    also heard that the radiator would be too small, also bought one that is 40-50% bigger. I will try to get two powerful fans on, so I'm sure good airflow.
    Tom
  4. #4
    Join Date
    Mar 2011
    Location
    Denmark
    Posts
    21
    pictures of camper body, chose to use two workshop trailer from the Danish military, glassfiber outer layer and foam core. Toltal 42mm thickness. Think it weighs about 500 kg with steel frame under the body
    Tom
  5. #5
    Join Date
    Feb 2017
    Location
    South Pacific Workers Paradise
    Posts
    4
    Nice work, looking forward to more details.
  6. #6
    Join Date
    Mar 2011
    Location
    Denmark
    Posts
    21
    some more old photos, from motor swap
  7. #7
    Join Date
    Mar 2011
    Location
    Denmark
    Posts
    21
    gearbox with 6 gears from a Mercedes E270 CDI, and the clutch is from Sprinter with greater torque. Toyota corolla shifter for Volvo transfer case.
  8. #8
    Join Date
    Oct 2014
    Location
    Corpus Christi, TX
    Posts
    365
    Very nice project. How much more Hp/Tq from the new engine? The 6 speed should help as well with the low axle gears.
    I'm not familiar with the TGB 1314, looks like a lot of extra bends in the exhaust pipe, or did you add a burrito cooker?
    2015 MB Sprinter Winnebago Era 70C
    1965 Scout 80 7.3PSD/ZF/203/205 D60F/14BFF
    Member: 4 Jackstand Wheeler's Association
    Quote Originally Posted by General Dwight D. Eisenhower
    History does not long entrust the care of freedom to the weak or the timid.
  9. #9
    Join Date
    Mar 2011
    Location
    Denmark
    Posts
    21
    Hi.
    Wiki says: 100 kW (136 PS; 134 hp) @5000 rpm. 210 Nm (155 lbft) @2200 rpm.
    It should be theoretically 75-80 km/h @ 2200 rpm. in 6 gear with Volvo portal axles. I chose om606.910 without turbo to make it easier for myself and keep the price down, and get the mechanical pump! Did not change much on the exhaust, used the same bracket. but went up by 1/4 inch. worst thing is that, I have not finished exhaust, still need 1,5 meters
  10. #10
    Join Date
    Oct 2014
    Location
    Corpus Christi, TX
    Posts
    365
    I like it!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
