17 " tires on a 06 rubicon ?
skunkriver
What do you need to do to put 17s on a 06 rubicon unlimited? Will a 1" body lift do it or do I need more? It's a daily driver but I like some weekend fun too ..
datrupr
I'd stick with the stock 16" wheels, go 3" lift and you should fit 33" tires no problem.
1leg
17 inch wheels would not be a problem at all if you stay with a tire that is the same height as your current tire.
How tall of a tire do you want to run? I would go with a 265/75/16. You could keep you current wheels and would only need a Budget boost 2inch lift. If you want to go this 17 inch wheels I would run. 255/70/17 or a 265/70/17. I have never used this size before so I have no recommened brand. Generally 17inch tire are more $$ then 16inch
I don't like body lifts. a 2inch budget boost is easy to install.
Tirerack 265/70/17 tires Click here
Budget boost lift kit example Click here or here with shocks
Here is some info that will help you gain Jeep Knowledge Click here
Good luck I hope this helps you out.
computeruser
17" tires are probably quite a bit shorter than what you've got already...so you should clear your fenders A-OK. As for your differentials, well...
skunkriver
I was thinking of using a set of 17s off of a 2009 wrangler rubicon
I did not check the difference in height of the ruby 16s and the ruby 17s.
alosix
If you're thinking newer ruby 17s (only rubicon 17s that I know of) they are just under a 33" tire.
BUT, and this is a BIG BUT
They won't fit an 06. They have a different bolt pattern. 5on 5 instead of the 06's 5 on 4.5.
you might be able to find some spidertrax style adapters f you really wanted to though.
DavidG
The stock BFG Mud on the 07+ Rubicon should be a 255/75-17 (about 32x10) on 17x7.5s, but as Alosix mentioned the bolt pattern is different.
