New Mog Life
Jostt
Yes, the tanks are making km's...no leacks and the temps after 200 highway km are betwen 40-45 degrees, on a 30 C° deegres sunny day, it is still hot here in Spain, the fuel comsuption is related whit the gearing, now At 90 km /h the truck is at 1950 rpm, so its low and more important is on the max torque área, so the smallest specific comsuption , on mud roads it is another history, it is first time I use the truck on offroad tracks during long time and I remenber about my Toyota kz73.....but at all the truck is very confortable in this ways, any info you need , let me know
Jostt
Last month was hard....24 days Outlook of home, now again at home it's time to fix some details, one of theme Is the tanks sensors, I was waiting looking diferent options and finally I bought the original votronic, as the dash , they are expensive, I hope I forget about theme in a long time, Nice thing aout it Is YouTube can adjust very well the stroke of your tank , Nice ...
Jostt
Dime more pics
LostInTheWorld
Builder/Traveler
I've just started researching water level sensor options for our mog. I was considering one of the external mounted surface gauges (like SeeLevel), but theses Votronic gauges look pretty nice.
We don't have a probe mount hole on the top surface of our tank. The probe hole is at the top of one of the sides. Do you think that we could bend these probes at a 90 degree angle and have the probe mounted to the top side of the tank?
Thanks,
Michael
Wyuna
Sorry to hyjack the thread Jostt, i've enjoyed reading your thread.
You can't go wrong with the Votronic range, they make some nice gear i ended up with the Triple charger, Jupiter panel, their switches and 1200 watt inverter
Im not sure able being able to bend the gauge, I've got a spare one at the work shop i can look at when i head back to the workshop on monday
Jostt
Hello, thanks for the info wyuna, the proves I use are from two types, the long one is a soft prove whit com conexión in the bottom, its mind, the probé has one flexi cable inside the thank , and another cable goes out and you have a hole un the bottom where is comected the com, whit a special rubber nut, It works, do you can cut the probé for your tank stroke and you have a potenciometer on the sensor , to calibrate It, these probé goes betwen110 mm to 20 mm , for sure you can fit 90 degres..the second type has no com external, and you have on the prove tho rigid tubes, this type is for shorter strokes and the reason I use like this is because the fresh Walter tank is plastic and the Grey thank water is stainless steel, I try to do some pics
Jostt
Finally I found the time to finish the kitchen, we manage until now the situation whit plastic boxes to store all the staff, we use plywood 15 mm to bild It , we have now some space avaliable...
Jostt
I LOVE It...but It is not for toast the Bread in the breakfast, you need some pacience, It takes 10/15 min to be really Hot, after It is very usefull and you forget about gas, It was my plan, the cost here in Europe is 1200 euros, What is not cheap but, when you are installing you understand why,it is a good machine.
Jostt
On the way to keep the neumatic system, Yesterday I install the Air dryeer from Atkinson vos, It Will replace the download valvle and the Alcohol inyector, Im trying to find a cartrige to keep also oil, not just wather , I think It is possible, any sugestión?
Jostt
Lines fixed and tested
LostInTheWorld
Builder/Traveler
We have a 18 Bar system in our truck, and I just got a MANN TB 1374/4 1703 cartridge. You might want to check the spec sheet for the cartridge, but I think it removes some oil as well as water. I think the 18 Bar dryers have a larger (M42x1.5) thread on the cartridge than the lower pressure dryers.
Michael
Jostt
Thanks Michael, Im very surprised whit the prices of this filters compare whit the 13 bar...its huge....as I imaginé wabco has one specific to Renove also oil, the price is 120€....its not a joke..
Jostt
Time to upgrade the front Fender whit the braket for the Warn 12000, I know It is not super power for pull a 6 T truck but I dont want to fit somthing heavy to use few times
LostInTheWorld
Builder/Traveler
Your winch looks very nice enclosed in the bumper like that. The winch on our truck is mounted on the front of the bumper and looks a little odd.
Michael
WonaWarrior
