Page 1 of 2 12 LastLast
Thread: My M1079 Plan
  1. #1
    Default My M1079 Plan
    Hello. First post for me here. I have been reading a bit and I have been thinking a lot about building a low budget expedition truck based on an M1079 Stewart & Stevenson.
    I am in the initial phases of finding a truck but I am one of those guys that try to plan ahead and like to visualize things. I want to go with an M1079 because it already has a box on it and although it is a bit small I think it can work pretty well with good planning.
    Planing for the usual things.
    - Solar panels for battery charging.
    - Small generator for extra power (when batteries are low or you need A/C or heating) under the box. Probably next to the exhaust.
    - Install A/C in cab.
    - GPS and entertainment system in cab.
    - Casette toilet in a wet bath (no black water tank and fuss).
    - 2 burner stove.
    - Fridge
    - Folding dining area that can turn into a 65 inch bed (can fit a child's mattress).
    - Relocating the original box windows (depending on what type of box I find).
    - Adding a folding "balcony" in the back (later stage).
    - Adding storage under the box and behind the wheel for propane tanks (simple and you can get it anywhere).
    - Adding small storage boxes where possible.
    - Check the possibility of a pass through to the original van box.
    I'm only in the initial stages and checking the possibility of even taking on such a project.
    And this is my plan for the box. I made rough measurements based on what I found online. Any comments are welcome.
    The dining area will fold into the wall while transporting and if you need more room. I'm also planing to make the inside bench fold in half (to seat one person) so you can pass through to the bathroom area even if the dining table is open. The table will also drop to the bench level to make a bed platform or about 65" long or fold al together so you can lay a mattress.
  2. #2
    Join Date
    Mar 2014
    Location
    Madison County, Alabama
    Posts
    26
    Looks good!
  3. #3
    Join Date
    Jul 2016
    Location
    Texas
    Posts
    348
    Plan on going slow and buying lots of diesel. I have a M1078 and love to drive it unless there's some place I need to be.
  4. #4
    Quote Originally Posted by M1078 View Post
    I'm fine with that. Where in TX are you?
  5. #5
    Join Date
    May 2016
    Location
    left coast
    Posts
    265
    These are growing on me more and more and can be had for cheap. Now if they would just do more than 60mph.
    2006 Duramax CCSB
    1991 V2500 Suburban Cummins Swap (in process)
    1987 Elky (LS1 swap-waiting its turn)
    1991 V1500 Suburban (for sale just 85K miles, cali truck, no rust)
  6. #6
    Join Date
    May 2015
    Location
    Idaho, United States
    Posts
    88
    So since it already has a box on it, are you saying you're just going to do a build- out of the existing box on it with the layout you have? Those rigs normally don't have a pass thru do they? If so you might want to consider more/bigger windows to compensate. Looks cool though.
  7. #7
    Join Date
    Jul 2016
    Location
    Texas
    Posts
    348
    Quote Originally Posted by zoti View Post
    Just north of San Antonio.
    http://overlandroad.life/
    1998 Stewart and Stevenson M1078
    2010 Nissan Titan Crew Cab 4x4
    2015 Nissan Titan Crew Cab Pro 4X
  8. #8
    Join Date
    Mar 2017
    Location
    Winthrop, WA
    Posts
    2
    We have one we're building out too. I wouldn't try to change the windows. The box is solid and the windows are nice. Moving and resealing your work is not worth it.
    We put our bed across the back (it's just longer than a normal mattress inside).
    The most complicated part is the electrical. Love to bounce some ideas off each other if you're interested.
    Ty
  9. #9
    Join Date
    Mar 2010
    Location
    Jämte i exil
    Posts
    557
    Fwiw, my camper (but not on an armytruck) is a similar box. I modified a futon sofa as its bed. To fold space-wise into a sofa is real handy, & when I am camping alone, often just leave folded to enjoy the extra floor space.
    I wish now, had I put the window lower or bunk higher, I could piss out the window at night.
    As far as electrical, its only as complex as you wish to make it.
    I suggest keep it simple, Being a EE & WE, I went nutzo with my electrical. It rivals a diesel submarine with options to source & deliver power. Great fun to build, but after its novelty wears off, Turns out I just switch on & off its lights.
  10. #10
    Join Date
    Mar 2014
    Location
    Posts
    26
    Quote Originally Posted by FBJR View Post
    You can get them to do more than 60, but it requires a laptop with the Army maintenance program in it. All of that is limited in the software. All of ours in the National Guard are tuned up to run a little over 70mph so we don't get run over on the interstate.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
