Just an other aluminium truck camper project
rhodos
Hello everybody,
just want to present my current project - a pickup camper with popup roof and hard side walls, basics are :
aluminium frame - welded, tubes 30 and 60 by 30 mm, 2 mm wall thickness, skin - aluminium sheet metal 1.2 mm, electric system - 300 Watt solar panels, batteries - 100A LiFeYPO4, Katadyn water filter, roof lift with electric driven spindle gear.
Truck : Ford Ranger with 2.5 l 4banger turbo diesel
So now some pics.
asset.php
first drawing
asset.php
start welding
asset.php
growing
asset.php
first fitting test
asset.php
lower frame (nearly) finished
asset.php
unfinished upper frame
asset.php
lift mechanism with end switch
asset.php
asset.php
batterie box
so much for today, I will post more pics and text as the project continues.
bye Werner
  • _www_htdocs_w0065e3e_magazinjo35_media_kunena_attachments_1914_entwurf01.jpg
  • _www_htdocs_w0065e3e_magazinjo35_media_kunena_attachments_1914_IMG_0940.jpg
  • _www_htdocs_w0065e3e_magazinjo35_media_kunena_attachments_1914_IMG_0970.jpg
  • _www_htdocs_w0065e3e_magazinjo35_media_kunena_attachments_1914_IMG_0972.jpg
  • _www_htdocs_w0065e3e_magazinjo35_media_kunena_attachments_1914_IMG_1084.jpg
  • _www_htdocs_w0065e3e_magazinjo35_media_kunena_attachments_1914_IMG_1095.jpg
The Artisan
Cool to see you are doing a screw drive system. I have a design planned for a lifting roof using the same technology.
Kevin
guidolyons
Addicted to Gear Oil
Ausgezeichnet!
Alright, that does it for my German vocabulary.
Nice job Werner, Looks interesting, keep adding photos.
You can insert the photos
Like this so it is easier to read
rhodos
thx for the friendly comments, forgot to mention one spindle drive pushes 330 pound at 8 Amp, the motors are rated at 9 amp continous and 30 amp short term!
rhodos
Here some progress - slow but steady ;-)
first a rolling "chassis" for loading and unloading the camper
start gluing the sheet metal to the frame
bye Werner
What are you using for insulation? 2.5 TD Ranger? If i recall, Ford offered a diesel in the Ranger for a year or maybe two in the mid 80's. I think they were like a 2.2 with no turbo. Very slow and no one bought them. Your truck looks much newer than those ones, and with the turbo, should handle your camper fine.
rhodos
Insulation will be XPS aka Styrofoam or Styrodur - 30 and 40 mm, inner walls on the upper lid from Forex (Hard PVC Foam), lower part marine grade plywood. Our Ranger has a 2.5l Turbodiesel, those models are not sold in the US but are very popular here in Europe - 140 HP and lots of torque.
rhodos
again some pic on the slow progress - upper part is finished and here we go : cutting sheetmetal, bend and glue it to the main frame:
rhodos
and again some new pics:
door hinge - Tilaband
first test
door
frame for service door
beside the LiYFePO4 batterie, the water filter and the Shurflowpumpe this box will house the electronics and a 12V compressor
WonaWarrior
