Thread: New from AEV: Ram ProCal 2013+ 1500/2500/3500
  1. #1
    AEV's Avatar
    AEV is offline Supporting Sponsor - American Expedition Vehicles
    Join Date
    Jan 2014
    Location
    Michigan
    Posts
    69
    Default New from AEV: Ram ProCal 2013+ 1500/2500/3500
    AEV's ProCal Module for 2013+ Ram 1500/2500/3500 trucks is now available as a stand alone unit! This innovative, user-friendly recalibration tool that has a variety of unique features. One of the most popular features of the ProCal Module is its ability to correct the speedometer when larger tires (up to 48” tall) are installed. When the speedometer is left uncorrected, there is a major degradation in the performance of the stability control (ESP), transmission shifting, and engine performance – the ProCal Module will eliminate these issues by ensuring that the vehicle is properly calibrated.
    Additionally, the ProCal Module is the only product of its kind that allows the user to recalibrate the TPMS system for larger diameter tires that have a lower inflation pressure than the stock tires – a common scenario that would otherwise lead to an annoying low tire pressure warning light. The ProCal will also recalibrate for axle gear ratio changes, allow users to turn the truck’s one-touch lane change feature on or off and determine whether or not the fog lights turn off or stay on with the high beams (for off-road use only).
    The ProCal Module is equipped with a series of easy-to-use DIP switches. By reading the simple instructions included with the ProCal module, the user can quickly dial in a code for the desired recalibration. The entire process can be completed in mere minutes – once the switches are set, simply plug the ProCal Module into the vehicle's OBDII and wait for the horn to honk, confirming that the setting has taken effect.
    Key Features:
    • Compatible with 2013+ Ram 1500, 2500 and 3500 trucks
    • Easy to use DIP switches
    • Recalibrate speedometer for larger tires (up to 48" tall)
    • Recalibrate TPMS*
    • Axle gear ratio recalibration (3.21-4.88)
    • Turn one-touch lane change on/off
    • Turn fog lights with high beams on/off
    • Optimizes ESP performance
    • Will not interfere with most performance modules or tuners
    https://secure.aev-conversions.com/s...-procal-module
  2. #2
    Join Date
    Mar 2011
    Location
    Your rearview mirror.
    Posts
    5,087
    Is there any plans to make procal modules for other trucks? Specifically a 2017 Ford Superduty?
    Well, a hooker would get the joke.
  3. #3
    Join Date
    Mar 2016
    Location
    Central Montana
    Posts
    47
    Thanks!! I've been waiting over a year for this news! Mine should be here tomorrow.
  4. #4
    AEV's Avatar
    Join Date
    Jan 2014
    Location
    Michigan
    Posts
    69
    Quote Originally Posted by plainjaneFJC View Post
    Sorry, we do not have any plans to make a ProCal for your application at this time.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
