Where to find plastic re-usable liquid storage bags?
Jim K in PA
I have been searching the web as well as through past threads here, and cannot seem to hit the right search terms, or perhaps nothing exists like what I am seeking. I am looking for a 2-3 liter liquid storage bag with a screw cap that can be used and re-used. Preferably with a cloth/canvas cover for abrasion resistance, but that is easily made after I find the bags! I have some odd-shaped storage spaces, and a liquid storage bag would make the best use of this space.
Thanks for any suggestions.
rayra
Weird. You're basically specifying a 100oz (3L) hydration bladder in a lightweight nylon cordura carrier. Common as dirt.
http://usplastics.com/
Or some milsurp 100oz camelback bags. Carriers can be had inexpensively via govt surplus
http://www.unclesamsretailoutlet.com/category-s/347.htm
Or something like a heavy vinyl solar shower bag, 5gal, $10
https://www.amazon.com/Coleman-2000...8&qid=1501595085&sr=1-3&keywords=solar+shower
or 5L collapsible water jugs, ~$10ea
https://www.amazon.com/Faswin-Colla...2&sr=1-4&keywords=collapsible+water+container
Jim K in PA
Thank you for the suggestions. Not sure why I brain blocked on water carriers, as they would be ideal (don't have to fill them all the way). I want to carry lubricants in them, so they need to be heavy gage plastic. I will probably just wrap them in cloth, rather than make or buy a bag-specific cover.
rayra
There are lightweight hydration covers that have a bit more flexibility than the bulkier military pack designs with extras. You could also very easily sew a protective cordura sleeve / pouch.
Another idea, spitballing, you could try using heavy duty / freezer food sealer bag material. I'd suggest making several smaller quart bags, rather than a long tube. Less trouble from a puncture or spill.
rayra
...Lasty, dont forget the collapsable Army canteen bag.
And those are 2qts. They're a little bulky / stiff. Probably won't really be quite as conformal as the OP wants, but they are sturdy / durable and have a standard canteen cap / mouth, so they're a quick pour.
And they are all of $5 at govt surplus.
http://www.unclesamsretailoutlet.com/2-QT-Water-Canteen-Collapsible-Green-8465011188173-p/6486a.htm
beware their shipping is quite high, you have to purchase enough stuff to make it worth it, if the cost matters.
Here's a simple 100oz carrier for $10
http://www.unclesamsretailoutlet.com/Olive-Drab-Molle-II-Camelbak-Hydration-Carrier-Us-p/2468.htm
Jim K in PA
If not Camelback type containers and you want a more DIY option.
Liners in coffee to go boxes or box wines are very durable. Can be placed in a cloth bag of your choice.
Several outfits make similar soft containers mostly looking like a ladies purse (I assume to smuggle drink into ballgames & festivals).
At least one is nylon, all velcro strappy probably MOLLE compatible too. Its intended to hold the pouch from a box wine.
Edit,
Ok. Now you mention lubricants...Those suggestions might work. Careful testing is in order, a leak will be nasty.
Yep - testing, and proper filling and packing is required. I will probably make an inner liner in the compartment to assist in cleanup of any weeps/spills. Several smaller containers will be a better strategy for spill management than one large one.
rayra
The 2qt army canteen bag would be great for gear oil. It even looks like there is a small spout within the cap for dispensing. Too bad they are out of stock. :(
That's actually a device for plugging in a drinking tube that is part of US / NATO Mil gasmasks. So you can drink without taking the mask off.
rayra
Sidebar--- Any options acceptable for freezing and resuse with food??
Food sealing bags. They come in a long roll / tube. The sealing machine is the expensive part. You can fill them with anything, seal and freeze. You could pre-pack all sorts of liquids or mushy foods, stews, soups, sealed in the bags and freeze them solid before a trip. They become your ice blocks and you can fit more in an ice chest, instead of losing half its volume to ice cubes. And things getting soggy in the slush. But again, it isn't an inexpensive alternative.
WonaWarrior
