Thread: Building material
  1. #1
    Join Date
    Sep 2017
    Location
    So Cal U.S.A.
    Posts
    5
    Default Building material
    I just saw "tear drop" made with aluminum (steel) studs- anyone heard of using this before? I believe it would be lighter and easier to use that a "2x2 wood" frame
  2. #2
    Join Date
    Jun 2009
    Location
    northeast coast
    Posts
    1,918
    aluminum -lighter maybe.
    steel - different material.
    how easier?
    harder on the wallet.
    you do know about thermal bridging, right?
  3. #3
    Join Date
    Oct 2015
    Location
    Canada
    Posts
    83
    Quote Originally Posted by retiredblue View Post
    There are campers made with aluminum studs,dont recal name right now,,do you know how to weld aluminum?
    It takes expensive equipment...
    Steel on the other hand is easy to work with..
    I would never use 2x2 wood frame,too flimsy and weak..
    2008 Silverado 4.8 V8 ,air,,G80 locker,110.000km..homebuilt camper made of plywood and epoxy,.
  4. #4
    Join Date
    Jun 2009
    Location
    northeast coast
    Posts
    1,918
    I dunno... there's lots of different woods and construction joints. adhesives & sheathings, too.
  5. #5
    Join Date
    Sep 2016
    Location
    NM
    Posts
    629
    I don't think a frame of any sort is optimal. The best campers are made of foam and fiberglass. Strong, light, waterproof, and much better insulation.
    2016 Toyota Tundra SR 4x4 Double Cab Long Bed 5.7L..... DIY camper on the way...
  6. #6
    Join Date
    Jul 2013
    Location
    burning time
    Posts
    591
    Or stitch and glue.
  7. #7
    Join Date
    Jul 2009
    Location
    El Segundo
    Posts
    1,498
    Our Class A motorhome has an aluminum framed body shell with solid foam core with thermal break. It's fairly common.
  8. #8
    Join Date
    Nov 2008
    Location
    Kodiak AK
    Posts
    173
    I think it depends on what your design parameters are for your camper. Is it just shelter? Or do you want to be able to carry weight on top?
    I'm currently building a camper with a steel subframe (16 gauge tubing) with ply skin sheathed in fiberglass, due to my own requirement that I be able to basically treat it as a contractor lumber/ladder rack if need be.
    I think you could build a very strong camper using all wood construction...especially if (as was mentioned above) you borrow some pointers from the boat building world. Epoxy really is an incredible invention, and combined with wood (especially plywood) is a match made in heaven. Anyone who can mix creamer into their morning coffee and put butter on their bread can mix and apply epoxy. It requires no special skill or expensive equipment, unlike welding aluminum. And if you spend a little time familiarizing yourself with the right ways to laminate up wood plys, you can get a tremendously strong product that will absorb vibration and flex with little-to-no fatiguing. Several well-known sailing catamaran designers (including Richard Woods of Woods Designs) have great praise for plywood and epoxy construction for this very reason, considering that ocean-going sailing catamarans are under incredible flexing loads and need to be strong enough to handle them without failure, yet also must be light weight enough to enjoy the speed they're expected to achieve.
    Cheers!
    Ed
    1997 Chevy K2500 4x4, 454 ci
    1998 Mitsu Montero w/Winter Package
    1983 Subaru GL 4x4 dual-range 4 spd
    1998 XR400R
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
