1800 watts solar Off-Grid Outdoors RV
Lc29er
1800 watts of solar! The electrical system on this Backcountry Series Outdoors RV is second to none. All top quality components installed professionally to ensure safe and reliable off-grid living. The 1800 watts of solar will keep the robust 600 amp hour battery bank charged even when running the Air Conditioner! Which by the way the batteries are connected to a 3000 watt Victron inverter/charger, that enables you to run the A/C and all 110 v appliances off the batteries/solar.
I have tons of pictures. Try this link or text me for the link. Photos
2022 Outdoors RV 28DBS
Price 66,000
Location Utah
The off-grid electrical install did not come cheap. This was a very expensive and thorough install.
Also included is a ProPride hitch. This hitch installed is ~$4,000. There will be absolutely no sway with this hitch. It's the best hitch on the market by far.
With two bunk beds, a huge dinette that converts into a bed, the couch bed and the main queen bed, you can sleep up to 10 people! This is the off-grid party trailer. -Queen Bed -Dinette 45x82 -Couch 52x70 -Bunks 49x74
Take a look at the fridge. That is not your average RV fridge. It's a 12 volt compressor fridge built by Dometic. Top of the line. It allows for 25% more room and they are more reliable than the propane fridges. It's very energy efficient and sleek.
Also included are several nice totes and bins. They fit perfectly and the previous owner insisted they stay with the camper!
You can also see a couple of small appliances are included ( toaster, water boiler ). Also some cookware by LeCreuset. They fit perfectly in the oven and again the owner insisted they be included in the sale.
The Outdoors RV Backcountry comes from the factory more capable for off-grid. But as you can see, this is not your average Outdoors RV. Tastefully and professionally upgraded. No expenses spared.
The 3600 watt LP Onan generator has only 13 hours. It runs perfectly but with the rooftop solar you will probably never need it!
Two Maxxfans help tremendously to create a nice air flow through the trailer. One in the bedroom and one in the bathroom.
Large full length awning is in perfect condition.
Large slide-out is also in great condition with the factory installed slide-out awning.
Dual pane windows throughout.
There is also under-bed storage not pictured.
Now I know what you're all wondering... Where is the toilet???
The toilet was removed when brand new and a portable off-grid toilet used instead. So the black tank has NEVER been used! I can install a regular RV toilet if you wish, or a compost / off-grid toilet. Just let us know which one you want.
Specs / Details: 100 gallons fresh water 80 gallons grey 40 black Fresh water tank heater 10 gallon gas/electric water heater 2x 40 gallon propane tanks 1800 watts solar 600 amps battery 3000 watt Victron inverter 3600 watt Onan Lp generator KYB Shocks MORryde CRE 3000 Suspension Dexter self-adjusting electric brakes Four Season insulation 30 amp cord included Anderson leveling blocks ProPride 3P hitch Dometic DMC4101 10 Cu Ft fridge
If you're looking for a top quality trailer upgraded professionally to be even more off-grid ready and safe, this is the perfect choice. Nearly $40,000 invested into this trailer.
Run the A/C without even having to turn on the generator. Never worry about batteries dying. Just have fun camping!
Call or text with questions 801-860-0035
Clemtiger84
