Toyota Land Cruiser Bj74 $25000 US
Bj74 Hunter
* All reasonable offers considered *
Primary Features:
• ARB front & rear air lockers installed by RADD Cruisers
• Rodney automatic extreme HD valve body installed by RADD Cruisers
• 5:29 differentials installed by Nitro gear
• AISIN 8000 lb 24-volt winch
• Okanagan suspension 2 ½” lift with new bushings
• Rear BOSS air bag suspension
Secondary Features:
• 150000 Miles
• Pyrometer boost & transmission temperature gauges
• Front & rear bumpers by yours truly
• Stainless steel roof rack
• Front suspension seats
• Toyo M55 tires 255/85 R16 with approximately 80% tread left
• 1.5-inch wheel spacers
• New windshield
• New E-brake cable
• New 24-volt radio
• Rear flood light
• 99% rust free, a little surface rust on frame
• LED front spotlights
• Turbo wastegate has been shimmed to 11 psi
• New cooling fan clutch
• Hella H4 conversion headlights lenses with Hella H4 100 – 90-watt bulb
• 24-volt trailer light flat 4 connector comes with receiver 2” hitch
• Toyota 80 series wheel rims
What the buyer should know:
• Intermittent oil leak from turbo downpipe connection flange
• Factory oil pressure sender gauge is malfunctioning but I have installed a sandwich plate on to oil filter mount so a new oil sender can be installed easily
• I imported this vehicle directly from a dealer in Japan in 2005
• I uninstalled the A/C condenser as I was getting continual leaks from A/C system but comes with A/C parts if you wish to reinstall
• Comes with a turbo gasket set
edit, 1986 Bj74, located near Osoyoos BC Canada.
quigleyth
