AEV Bumper Water Tank: Gravity Spigot
MattJ
I've always wanted to use the water tanks in my AEV rear bumper, but couldn't stand the thought of hassling with the hand-pump dispenser that is required to squirt the water out of the tanks. So I spliced a spigot onto the connector hose at the lowest point. The spigot tucks up inside the bumper with a velcro strap when not in use. I've tested it a few times. No leaks. Capacity of the tanks is around 4 gallons.
y4mQNdOYLvbG5wNv120rbuodDtUJwy9qEk1hA4SivDbU7HfmWKRQKO9-18hlSfFWV05B4wiJ3H9NdXhYzZMGf9m0sTUU9IFhoEXJqEpbQitpQxRH4yRgt1cOFgpF9S0841AKbZzCHVd4_V2IOqz5UsUADb3piOoJCb-Z10xCcWb8fnSDXTBGZc7C9TGXaeUyk4W0TB_9WvNtHelanKO5L82Cg
y4m_po3WumOaLo1dTHeErF-osjPuq6MBJ5Vi5K_oi6kRg_7RGm2uD4J3CPJIuHsX86pfqjLOljC6RHY_Xyr7kd02xLkg7kEnsT2kPL0dy93xMQIrUdGfF4fo61NYaO73jUw8kFTbmNdF1vj5tQ0gbszTFtGNbSqEUWbsfOkbz71JQaNhMOvFT4D4K_uBj-SVErdNTGP28487XDhIGE23oPINg
y4mFpiTM0R2k4IHP5B1KLQSl15_pjPeRFbPViHESpAAMuhIbh90g22P2KdwTQyXZlc7qYFFpFzMN8J0LQHRQALv9XylCXGHxVYgMdRVw9z5FVKJ5pGurlAWtcE2lBesFydlrYb8Kiw3kBArgznEb1ql45lrExM7lEMjJKSUXlIEW3gW1SHv4P02TDWBTDT6Oq8fxoYIdvszWd8Fa5uI8ZGJ1g
I didn't mention it in my post, but there ARE two separate tanks with my configuration. Due to the t-junction I installed, the fluid pressure isn't strong enough to allow me to fill both tanks from one side. So I had to drill a cap into the other side tank and fill it separately. The spigot drains from the right side first, since it has a built in air vent. Then I loosen the cap on the left side and it drains out the spigot next. If anyone can figure out a better way to splice a spigot onto the main hose, I'd love to see it!
Someone on another forum suggested my configuration is great for whisky on one side and rum on the other . . . I guess to keep the fellas AND ladies happy . . .
y4mcwJ4-fuNUvLxnjlqGBhFJokWgv5OED4VjpxiMi2WUDZwhxC_nQSbJ6xe7sjgTzUn_VM3VFKkPtQf1WRQNyAzjljGqsU5iXZcIPm7jJHxo9g539hkJOYpYxBc57LS3zM9sgbBqDvITg2SPsH71_vQSoyxHDUh9OU59tPXvTwzZMxSvTPNJCR3OfCELB1I5mKVYEg6IDPwp2A9dHE7vxSW2Q
I just ordered these. Looks like I will have four extra to spare. PM me if you want me to send you one!
y4mkOlUd1BW-hPd66YOHZNRwwtPaNuHZFFj8hVPu2RqULiaROfzLjzhZRME899VDZ5XsBn1HQ-1fOQIyd37gFyHIfA-0g9FoONg_UvJ-m2vOtxOoZZtfi_zo7c8G94yaWuy1AkHKqlgZtd9vJBNnsOgvxgTdARXtj4ca3LynC_2s8HqKcEHI_jd4UDTroWn8pxc0v_-RNFAEICNS2bh7WBwLg
Well, I learned that a 1/2" CTS (copper tube sizing) is 5/8" outside diameter, which is exactly what I was looking for! Here are the photos of the upgraded t-junction. I still have to fill both side tanks separately, but this upgrade looks a lot cleaner and actually wedges inside the bumper very snug.
y4md5Af0JlFIz3Kluy99V1XUc3DUV13yMBmwHTOd14q0hCNg1tqwE9r0Q7qVJsuwVyA3uyB05oJD3g8ll5YxapJTeJzwBSbLAn-pKG-Uw2uLnPiIh_DqeNOgKtk02O-9SDrrjWkHAJboNmS8BpttslzYlwcUwJUN12lyMJo_PCKOhDtGz3ft5hSEEaEhm3FsL4n_kBIkrEEAkTodDOv0kwUFQ
y4mJQr79WN8GTPLEZ2a6xycJO1srhk7fj3GwK6xI6tqWLUkiAsqb4zxF-kY18Hh153UiNO6HeyArCjlnCeXcgCdezuqQzCugvNa5dp38ZojIxALADrRpalw6MJRW_ORPxtiyYLjmbz7HDYPLzB6nj26UW3J02sGc2yZcYL3XWJtOuXVuDQXRmYghXQ4iMlpK1cXNAa2ytpluHyCQR298cv8wQ
y4mqVZdNCgzLBFyD62QRfG4y2Mvih7hT1JaeGzc8LkLrj9Y-j18oSFVnlYcL8tlPxLy1t9kpVR1d_3Spe7TcaMCOElwuMcetJA3aKbZ1Hqo1OsYHAHqfDRFuG-ycOPJiEckV165pHUuEKl86WDXlRaXsbPO_aGoS_D7oWQJLQqTuE_EggvRBtTvCG2LDz6WP7eKtvHR-cP5C--qgGXskMnRKw
5mouse
