Thread: NISMO Shock Question
  1. #1
    Join Date
    Dec 2016
    Location
    NWA
    Posts
    2
    Default NISMO Shock Question
    Rookie question,
    I have 2007 Nismo that needs rear shock replacement, I am looking for suggestions for a stiffer setup that would not sag in the rear as much. I have a camper shell with basket, bike racks, etc on it so it weighs quite a bit. Any ideas or suggestions would be greatly appreicated
  2. #2
    Join Date
    Mar 2010
    Location
    N.W.A.
    Posts
    765
    Shocks provide damping, the springs hold things up.
    Your rear leaf springs are probably flattened. A replacement spring pack would be your best long term solution, Old Man Emu leaf springs will set you back around $500. You could try an add-a-leaf to get some arch back into your current springs but they will probably flatten back out over time but they are much less expensive than total replacements. PRG's two leaf spring pack is probably the longer lasting add-a-leaf solution, single leaf add-a-leafs run about half the cost. With either option also factor in the cost of replacement u-bolts, they should be replaced any time they are removed.
    Which ever way you go you've a buddy in the area with a big garage who's swapped around rear leaves in a Frontier a couple of times
    Quote Originally Posted by Hilldweller View Post
    ready for an expodition
    2005 Nismo Frontier 4x4 CC
    KG5VFD
  3. #3
    Join Date
    Dec 2016
    Location
    NWA
    Posts
    2
    E.J.,
    Thanks for the help, I'll holler sooner than later.
  4. #4
    Join Date
    Mar 2010
    Location
    N.W.A.
    Posts
    765
    Sounds good man. If you haven't already you should skim through this thread as well.
    KG5VFD
  5. #5
    Join Date
    Nov 2015
    Location
    Penticton, BC
    Posts
    253
    OME Dakar leaf pack. I put a similar style on my old Xterra (the Ironman HD leaf pack - don;t know if they are still available), and I've just installed the OME Dakar leaf packs on my Tundra. The OME leaf packs are great, super stout. I also added Firestone airbags to help out with the added weight of our (in production) Four Wheel Camper.
  6. #6
    Join Date
    Mar 2014
    Location
    PNW
    Posts
    61
    Quote Originally Posted by Trikebubble View Post
    +1 on those. I have had zero sagging issues since I put in a Dakar leaf pack. At most, I end up leveled out.
  7. #7
    Join Date
    Dec 2014
    Location
    Kootenays
    Posts
    183
    +2 for the Old Man Emu. Best upgrade ever
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
