Reverse lights for rear bumper
curious... how long have you had these installed @acg ? I have a set of cheap floods for ditch lights and they have water behind the lenses after only a few months. I'm going to be swapping them out for something from a more reputable manufacturer. I am however, wanting to add flush mounts like what you have installed to the rear bumper and wonder how the low cost options are holding up.
Thanks
robert
I've got one of the inexpensive flush mount floods in my bumper; the right side is damaged and I can't put one in there- doh! :oops:
Two things I'd highly recommend- if you have a reverse camera be sure to look at the LED temp. The more bluish light washes out in my Pioneer camera so I wish I had a warmer color, down around 42-4300 would be better. Second, when you get the lights, pull them apart and if they don't have a decent seal in them then run a thin bead of silicon, RTV or some sort of sealant around the glass or they will fog and end up near worthless.
Betarocker
I used 4 of these. Had some 1/8" thick aluminum angle left over from some curtain wall glazing which I cut and drilled. Painted black, installed lights, and wired together and added a length of 2 conductor to tap into the factory reverse wiring.
MOguy
Thanks
I got my son a set of these: https://www.amazon.com/gp/product/B01EAN9DUU/ref=oh_aui_detailpage_o01_s01?ie=UTF8&psc=1 he did this and they still work. I also have one mounted on the front of my Jeep and one on the back. In the past I have always be let down by cheap lights and have only run KCs for the last ten years but theses cheap lights can take a hit.
UltraHDGames
I just have cheap Amazon flush mount pods in my rear bumper and for what they are I'm fairly happy, I choose a flood pattern for mine. As we speak the only thing that concerns me like every cheap led is the build quality and life to them, so far they haven't had moisture inside and I even dunked them into deeper water a couple times but I guess we'll see how they hold up over time
These are the ones I bought https://www.amazon.ca/gp/product/B01K9FOJYI/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
When they do eventually give out(not much faith for the price I paid) I'll get some nicer Kodiak LED Flush mount pods
Ngneer
Give some info on this setup man, NICE numbers etc of the individual lights very nice out of the way and simple. Looked on the website didn't c anything resembling what u have. Thanks
UltraHDGames
Directed towards me? Looks like the amazon link I posted no longer sells the lights I had bought. So far mine are still holding up but next month I am replacing them for the nicer Kodiak flush mounts
UltraHDGames
Update...one of the rear pods stopped working last night, started with 2 of the bulbs not working and now the whole pod...pay for what you get
BigSwede
The Credible Hulk
I was gonna add an aux reverse light, then decided to keep it simple and just get some nice bright LED bulbs for the factory reverse lights.
JersT4R
I did the same thing, JDM LEDs on Amazon. So far they’ve been great!
Hummelator
18 watt led Chinese lights from eBAy. I went with a flood/spot combo
Would like to have flush mounted them but didn't have a good spot and didn't want to cut into the bumper.
So far I have them wired into a switch in the dash on a curcuit that stays live when the vehicle is off.
I paid less than $30 for the pair and couldn't be happier. They throw off tons of light.
The plan is to tap into the reverse lights wire and have it trigger the relay but I'll have to wait until we come out of the deep freeze to get it done.
WonaWarrior
