Thread: 2000 G500 Europa
  1. #1
    Join Date
    Jun 2017
    Location
    Oregon
    Posts
    4
    Default 2000 G500 Europa
    Hi All
    I am considering one for a great price that has 240,000 miles on it. I assume as it has a few leaks I will need to do a gasket refurb and and overall once through, replacing everything rubber.
    Am I crazy considering on with so many miles?
    I am going to post a bunch of images, but it needs AC help, valve cover gaskets, brakes redone, B - Service pending, check engine light is on, transfer case leak, transmission pan leaking.
    Co you think if I send it to the right shop, I should consider it, if I am okay with spending 15k to get it all revitalized, or should I budget more?
    Should I run for the hills?
    Thanks
  2. #2
    Join Date
    Sep 2016
    Location
    Los Angeles, CA
    Posts
    14
    There is a long thread on this truck at ClubGWagen https://clubgwagen.com/forum/viewtopic.php?f=34&t=9476
    I almost bought it, but the CARB sticker to get it back in California seems to be gone, so that killed the deal for me. I'm in California. I was debating the same question you posed.
  3. #3
    Join Date
    Sep 2015
    Location
    California / Neuchâtel, CH
    Posts
    852
    Moral of the story is if you have a sticker don't keep it on the vehicle. Get it laminated, and stored with whatever other files in a safe or deposit box...
    2006 Discovery 3
    1995 Discovery
    1990 110
    Instgrm:CondorDavis
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
