Page 1 of 2 12 LastLast
Thread: The Rogue Overland 2012 Nissan Xterra PRO-4X Build
  1. #1
    Arrow The Rogue Overland 2012 Nissan Xterra PRO-4X Build
    Hello all !
    You will have to forgive me as I am not always active on the forums but I wanted to share the build on my 2012 Nissan Xterra Pro4X. My goal with this build, which I have done myself since purchasing new in 2012, was to build the ultimate combination of an expedition ready / rock-crawling go-anywhere I want rig
    If you would like to follow the adventures on Instagram we are @ RogueOverland
    My Photography page is @VegasVuk
    The Build List:
    Front Suspension:
    • Titan Swapped
    • PRG Upper Titan Control Arms
    • Factory lower titan control arms custom boxed
    • SAW Race Runners w/ Eibach 650lb springs
    • Sway bars removed
    • PRG outer heim tie rods w/custom inner tie rod
    Rear Suspension:
    • Alcan 3.5" + 650lb rear leaf packs
    • Bilstein 5125 rear shocks
    • Sway-bars removed
    • Nisstec rear shock protectors
    • Nisstec U-bolt flip kit
    • Custom modified timbren bump-stops
    • Extended brake lines w/custom e-brake cable mount
    Drivetrain:
    • 2012 M205 Front Differential w/ ARB Air Locker
    • 5.12 Re-gear
    • M226 ARB Air Locker with custom D44 axle shafts
    • ARB nodular iron rear diff cover
    • Dan's driveline custom made double carden rear drive shaft using spicer 1310's
    • Custom made front driveshaft
    • Factory nissan titan front CV-Axles
    • JWT Performance clutch and Flywheel
    • PRG Short-Shift Kit
    Powertrain:
    • Bully dog tuner
    • Borla Stainless cat-back exhaust system
    • Airflow snorkel w/Volant modified air box (fully sealed system)
    • Airaid TB spacer
    Electronics:
    • Dual battery system using the following components
    • Optima red-top
    • Oddessy gel cell motorcycle battery
    • battery isolation switch w/monitor
    • dual rear-vehicle mounted battery posts w/gauge
    • rear Edison power strip accommodating an additional 150amps w/usb output
    Lighting:
    • Aurora roof mounted 30" LED Bar
    • Amazon 20" curved front bumper mounted LED bar (downgraded 08/2017)
    • OffroadGorilla LUX Rock Lights x 4
    • Amazon specials led cube rear bumper mounted LED's
    • ZAMP Solar LED Awning light bar kit
    Wheels/Tires:
    • Level 8 Motorsport 16" Bully Pro Wheels
    • 315/75/16 (35") Pro Comp Extreme MT/2's
    • Spidertrax 1.5 " Wheel spacers
    The Armor:
    • Hefty Fabworks Front and Rear Bumpers
    • Hefty Fabworks rock sliders
    • Hefty Fabworks full aluminum skid plates
    • Custom built rear corners that tie into the frame utilizing 1" .120 wall tubing all custom bent and welded
    Exterior Gear:
    • GOBI stealth series roof rack
    • GOBI rear ladder
    • CVT Mt. St. Helens Hardshell Tent ( UPGRADED 08/2017)
    • ARB 79" Awning
    • Custom mount ROTOPAX setup allowing for 10 gallons of fuel and 6 gallons of water to be carried
    • Trash A ROO !
    Recovery Gear:
    • Smittybilt 10k X20 Winch with/syn line
    • Factor 55 Pro-Link
    • MaxTrax x2 / Bubba Rope !! (Added 08/2017)
    Interior:
    • Custom interior storage system
    • raingler netting
    • OBA unit w/compressor
    • Sweet LED lighting
    • ARB 63L Fridge w/slide
    Misc:
    • No body Lift
    • Kenwood 2m Radio w/Diamond h770b whip
    • CB Radio w/firestik whip
    • Lots of love and money
    Thanks for reading !
    -Andrew
    http://www.rogueoverland.com
    http://www.andrewjphoto.com
    Last edited by Rogue Overland; 11-29-2017 at 10:44 PM. Reason: added interior shot
  2. #2
    Join Date
    Aug 2017
    Location
    Arizona
    Posts
    24
    Look's great! Could you add pic's of the rear? I would be interested in seeing that if possible.
  3. #3
    Join Date
    Oct 2016
    Location
    Minneapolis SW Metro Minnesota USA
    Posts
    148
    Wow thats one heck of a build...
    Titan swapped , with 35's and properly re-geared.
    2012 Nissan Frontier Crew Cab Pro-4X, Radflo, SPC, PRG, Bilstein, Shrockworks , Leer, Antec, Magnaflow.
    My Truck "The Moose" build thread Click on the link below:
    http://www.expeditionportal.com/foru...stories-MNCarl
  4. #4
    Join Date
    Oct 2013
    Location
    Seattle, WA.
    Posts
    371
    Great looking truck man! I've seen this on Instagram and have to say its one of my favorite xterra's out there.
  5. #5
    Quote Originally Posted by IAm_Not_Lost View Post
    Yes- just realized there are none, here are a couple different ways I have run it - always changing!
    Quote Originally Posted by MNCarl View Post
    Thank you very much ! Its been a labor of love, started with the 4.56's and found the 5.12's to be perfect with the manual
    Quote Originally Posted by Dmski View Post
    Thank you !
  6. #6
    Join Date
    Apr 2016
    Location
    Massachusetts
    Posts
    171
    Awesome!!
    Just curious, ever put it on a scale?
    Nissan Frontier 2016 CC LWB SV 4X4
    BFG KO2
    2" X 2" PRG AAL
    Firestone Air Bags
    FWC Fleet
  7. #7
    Quote Originally Posted by Josh41 View Post
    Awesome!!
    No I haven't but its on my list to do when its fully loaded - very curious
  8. #8
    Join Date
    May 2013
    Location
    Ohio
    Posts
    156
    Wow man, amazing rig. Those pictures are amazing.
  9. #9
    Quote Originally Posted by 07BlackSpecV View Post
    Thanks man - nice build yourself !
  10. #10
    Join Date
    Nov 2015
    Location
    San Diego
    Posts
    14
    Always like seeing you rig Andrew beautiful build . see you in a few months on Mojave Rd
    FLBLFY
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
