Thread: opinions on building a FUSO FG from a FE
  1. #1
    Join Date
    Dec 2017
    Location
    Atlanta, Ga
    Posts
    4
    Default opinions on building a FUSO FG from a FE
    Looking for thoughts and opinions on converting a FE to FG 4x4. The FE are reasonably priced in the 2000-2006 model years but the comparable FG seems overpriced (US Market). I found a couple of FG 4x4 trucks in scrap yards and thought about acquiring the front axle and bits and maybe using a aftermarket transfer case. The scrap yard will not sell the transfer case without the transmission. Anyone done it?
    Thanks,
    RJ
  2. #2
    Join Date
    Oct 2014
    Location
    S Atlanta
    Posts
    457
    I will be doing it with ford F350 super duty axles on my 07 fuso.
    Kevin
  3. #3
    Join Date
    Dec 2017
    Location
    Atlanta, Ga
    Posts
    4
    Hi Kevin,
    I assume the FUSO will have the same frame rail width problems as the Isuzu. The solution on the crawler hauler was not pretty and I would be concerned with the bending load of the brackets they created to handle the 3 inch width problem between axle and frame. I look forward to following your build.
    forum.expeditionportal.com/threads/160699-NPR-4wd-conversion-and-camper-build-thread?highlight=isuzu+project
  4. #4
    Join Date
    Nov 2010
    Location
    Canberra Australia
    Posts
    1,842
    This topic has been discussed previously, but to summarise...
    You need to be mindful that the chassis on a FE is different to that of the FG, in that the FG has quite a large step down behind the gearbox.
    The reason for this is to lift the cab high enough to give space for the front diff. The FG diff's pumpkin is pretty central, so without enough clearance it will hit the sump. With a different diff you might have an easier upgrade path, if the pumpkin is offset.
    My attempt to build something to go somewhere else...
    Canter4x4.com
  5. #5
    Join Date
    Aug 2014
    Location
    Nashville, TN USA
    Posts
    493
    Quote Originally Posted by RjAtlanta View Post
    Hi Kevin,
    I've since redone all the leaf spring mounts. I wasn't concerned with their strength so much as they were ugly and the rear mounts were welded to the frame. The front mounts were welded too but to the front section, separate from the main frame. Either way I redid them to add a couple inches of height, more caster and to make them look nice.
  6. #6
    Join Date
    Dec 2017
    Location
    Atlanta, Ga
    Posts
    4
    Sorry JavaJoe, I actually missed your front updates in the mix of pics for the rear suspension changes (page 14). Do you think you have enough clearance/travel between the diff and engine? Did you need to make changes to the steering? I guess I should ask this on your thread and read it more thoroughly
  7. #7
    Join Date
    Dec 2017
    Location
    Atlanta, Ga
    Posts
    4
    found the steering post
  8. #8
    Join Date
    Oct 2014
    Location
    S Atlanta
    Posts
    457
    RJ,
    Will know more when I get into it. Still deciding if I want to go custom leafs with my 03 supers or go to a coil with the newer axles and a custom radius arms.
    Kevin
  9. #9
    Join Date
    Aug 2014
    Location
    Nashville, TN USA
    Posts
    493
    I wanted a bit more differential to engine clearance too so that was a factor in raising it some.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
