Page 1 of 2 12 LastLast
Thread: Frigid Cold Start in Dallas
  1. #1
    Join Date
    May 2016
    Location
    Tampa, FL
    Posts
    399
    Default Frigid Cold Start in Dallas
    I did a 20 degree Cold Start without having the engine heater plugged in last night, just to see how it would do.
    I only cycled the glow plugs the one time, and I do have Stanadyne in it, so I'm sure that helped a bit.
    Is this about the same as some of you Cold Weather Guys?
    Eric S.
    2000 E350 Quigley 4x4 Ambulance 7.3 PSD (AmboLander)
    Build Thread:
    http://www.expeditionportal.com/foru...other-AMBO-Rig
  2. #2
    Join Date
    Jul 2015
    Location
    Astoria, OR and Manama, Bahrain
    Posts
    97
    shoot man, i thought that sounded pretty good. Which viscosity oil are you running?
    '05 E-350 6.0 cargo, UJOR 6" 4wd convert with sterling rear, High output alt, Infinity DP Tuner,BPD: FICM, water pump, oil cooler, driveway-built intake...
  3. #3
    Join Date
    Aug 2013
    Posts
    282
    Yep! right on with the frigid mornings we have been having here in chicago. -8 deg F this morning but i plugged the van in last night as I have 10W-40 in the motor....i know...i know. Even with temps in the single digits (5 deg f) , the van fired up after a 3 cycles glow plugs.
    2000 E350 Cargo PSD MPV Build (in the works) MPV UJOR Build
    - Tow mirrors
    - ScanGauge II w/ X-Gauges, Pyro & Boost
    -DP Tuner F5
  4. #4
    Join Date
    May 2016
    Location
    Tampa, FL
    Posts
    399
    Rotella T6 5W-40 (Synthetic)
    Quote Originally Posted by SHAFT View Post
    Eric S.
    Build Thread:
  5. #5
    Join Date
    Oct 2011
    Posts
    1,925
    While not as cold as your part of the country, 46deg in Florida Is chilly.
    Quick video of my start up.
    https://youtu.be/GEKN8sy_t4Q
    Once the volts bounce back to 12.2 I turn the key, using Rotella 15/40 dino...
    Current:
    2001 E350 EB HT PSD w/ a bunch of stuff.
    Had three other E350s...
  6. #6
    Join Date
    May 2016
    Location
    Tampa, FL
    Posts
    399
    Not sure where you're at, but I live in Tampa (Dallas for the holidays).
    And yeah, we don't normally get too cold for it to be an issue.
    Quote Originally Posted by Bbasso View Post
    Eric S.
    Build Thread:
  7. #7
    Join Date
    Jan 2008
    Location
    Hibbing MN
    Posts
    19
    I usually hang out in the full size and jeep sections, but I saw the frigid thread and had to check it. I envy your 20 degrees this week
    the Duramax did not make it this morning....had to take the gasser
    gotta have that red bottle diesel 911, a spare fuel filter or two, good batteries and you are good to go... most of the time
  8. #8
    Join Date
    Oct 2011
    Posts
    1,925
    -35? Oh hell no. Never. lol
    (I'm in Jacksonville Beach area...)
    Current:
  9. #9
    Join Date
    May 2016
    Location
    Tampa, FL
    Posts
    399
    Block Heater on it?
    Quote Originally Posted by dmoo View Post
    Eric S.
    Build Thread:
  10. #10
    Join Date
    Jan 2008
    Location
    Hibbing MN
    Posts
    19
    Quote Originally Posted by FDM2012 View Post
    Block Heater on it?
    oh yeah, they basically come stock on the trucks if the delivery destination is Midwest-ish. But this extreme cold is tough on everything. I take the gas ride if its not forecasted to come above zero for the daytime high temp just so I don't gel up sitting in the parking lot at work.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
