Page 1 of 2 12 LastLast
Thread: Canter model decoding for Australian models
  1. #1
    Join Date
    May 2015
    Location
    Brisbane
    Posts
    13
    Default Canter model decoding for Australian models
    Hi,
    Can anyone direct me to information to decode Australian Mitsubishi Canter model numbers?
    Most of the info I can find relates to overseas models or doesn't include the letters/numbers in some of the trucks I am looking at.
    Cheers
    Dave
  2. #2
    Join Date
    May 2012
    Location
    Brisbane, Australia
    Posts
    218
    I tried below links and got some information, not sure if that interests you.
    Looking forward if someone have a link for Australian models.
    https://www.mitsubishicars.com/owner...in-information
    https://www.vindecoderz.com/EN/Mitsubishi/Canter
    http://en.vindecoder.pl/
    https://aidjapan.wordpress.com/2010/...ubishi-canter/
    FoxRoo - Current project, 2003 Canter FG649C SWB Camper
    http://www.expeditionportal.com/foru...er-Truck-Build
    Photos from Simpson Desert Trip: http://gigglepedia.com/p/portalg.asp?g=Simpson-Trip
  3. #3
    Join Date
    Mar 2010
    Location
    Brisbane, Australia
    Posts
    460
    Hi mate, if you get the vin number or QLD REGO number i should be able to help you.
    Pete and Kel
  4. #4
    Join Date
    May 2015
    Location
    Brisbane
    Posts
    13
    Thanks for the replies.
    I'd like to be able to work out engine types and chassis lengths etc as I browse the net without having to bother others all the time.
    This is the best explanation i have found so far but appears to be different to whats available in Australia.
    https://carused.jp/mitsubishi_canter/spec
    eg: This one i was looking at doesn't fit FG639W6
    Dave
  5. #5
    Join Date
    Mar 2010
    Location
    Brisbane, Australia
    Posts
    460
    FG639W6 Engine 4d34
    1995- 1997 2door
    4X4
    VIN should start 6F6G4G87D.
    Hope this helps.
    Pete and Kel
  6. #6
    Join Date
    Dec 2010
    Location
    wattle glen
    Posts
    158
    Hi Dave,
    I assume your 92 model is 2wd?, from what I know there has not been a lot of significant change in chassis lengths over the years, and the 2wd chassis are generally longer than the 4wd variants.
    As an example, the current model 4wd https://cdn.fuso.com.au/Docs/SpecShe...wide%20cab.pdf has 1808mm rear cab to axle and the 2wd https://cdn.fuso.com.au/Docs/SpecShe...rew%20Cabs.pdf has 2271mm for the same spec. and these figures are pretty close to your quoted estimated figures.
    Dave
  7. #7
    Join Date
    Aug 2009
    Location
    Brisbane, Qld, Australia
    Posts
    613
    Mr Nakajima may be of some help .....
    I have an FG649E
    FG 4wd
    the 9 in 649 is 4D34 engine
    the E is 6m chassis (which in other places has been called "medium wheelbase" as opposed to "short" or "long")
    I 64 seems to be some model progression.
  8. #8
    Join Date
    Aug 2009
    Location
    Posts
    613
    I was looking for something else and tripped over the following, from the front of my (around 2005) manual
    so my FG649E is (F) forward control, (G)diesel, 4wd, (6)wide cab, (4) gvm 6000-6900kg, (9) 4D34-T, (E) 2780mm wheelbase
    char 1 Vehicle Type
    F = forward control
    char 2 Basic loading capacity, drive system, fuel
    E = diesel engine, payload 2000 to 3500 kg, 4x2
    G = diesel engine, payload 2000 to 3000 kg, 4x4
    char 3 Cab style
    5 = standard cab (1695mm)
    6 = wide cab (1995mm)
    char 4 vehicle variations suspension
    3 = rigid axle light duty vehicle (payload 1500 to 3000 kg)
    4 = rigid axle light duty vehicle (gvm 6000 to 6900 kg)
    5 = rigid axle light duty vehicle (gvm 7000 kg or more)
    char 5 engine
    4 = 4M42T
    9 = 4D34-T
    char 6 wheelbase
    FE
    C = 2750mm
    E = 3350mm
    F = 3760mm
    FG
    C = 2530mm
    E = 2780mm
  9. #9
    Join Date
    Mar 2010
    Location
    Brisbane, Australia
    Posts
    460
    Oh .
    I have rego number now i will check that on monday at work we i am not too busy for you.
    The Vin number should on the plate in the lh side door frame.
    Pete and Kel
  10. #10
    Join Date
    Jan 2013
    Location
    Bilambil
    Posts
    12
    i have this
    if you PM me ill send you a dropbox link
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
