RAM Promaster conversion
Still haven't sold my Promaster, and just dropped the price. Full ad (with photos) located on Portland OR Craigslist. Type in Promaster Camper and it should pop right up. Please feel free to ask any questions. Thanks!
2017 Promaster with 8650 miles
74" stand up height inside cabin.
225w polycrystalline solar panel, 20A MPPT charge controller, and a 50Ah lithium battery. Renogy 1000w pure sine inverter with outlets for appliances/charging devices and USB port. Shore power hook-up.
Isotherm 4.6 cubic foot Cruise 130 refrigerator/freezer
Propex HS2000 propane heater.
Wedgewood LP stove, plumbed with copper pipe.
Maxxair roof vent fan
Motion Windows brand side door window
Extra deep stainless steel sink with decorative faucet, operated by water efficient foot pump.
RVS backup camera.
Captain and passenger swivel seats.
Maple framed cabinets with red oak and cherry doors. Taiga nut knobs and stainless steel latches. Doug Fir laser engraved accents.
Rough-hewn hemlock walls and ceiling, installed with stainless steel hardware. Insulation of walls and ceiling is 1.5" rigid poly board
LIFEPROOF vinyl flooring is completely waterproof. Step up box to drivers area, provides resting area for feet when seats spun around to face cabin.
22lb VIKING brand propane cylinder, cradled in a custom aluminum welded cage, bolted securely to the floor. Simply remove the bungees and pull out your cylinder for a refill.
LED lighting throughout. 4 circular "puck" style lights under main cabinets, and a strip built into a custom wall mount on one side.
The memory foam mattress measures 70" in length, and 54" wide (full-size width, but slightly shorter in length). Cozy for two, decadent for one.
Teak spice rack, paper towel holder and cup holders. Folding hooks along one wall provide a location to hang jackets, yet flip up out of the way when not needed.
Custom insulated blackout curtains for each individual window control temperature fluctuations and provide privacy. Black on the outside for stealth and a pleasant blue on the inside. These snap into place easily with mounted hardware.
15 gallon freshwater tank plumbed to the sink, along with a 15 gallon gray water tank are stored in the "garage area" under the bed. These tanks are held securely with a custom fabricated cage bolted through the floor, yet are easily removed for cleaning. Fittings installed for filling/draining, and hoses for each.
All propane has been hooked up with copper pipe, flared and fitted correctly. Multiple shut-off valves offer another safety precaution. We've also installed a LP/CO2 detector directly in the main living area, which is hardwired to the battery.
HButton
