This is a fully restored 1947 Bantam T3-C trailer.
Restoration took place in September 2019, lid added September 2020.
Two trips out West, zero issues. Trailer has approximately 6,000 miles on it since restoration.
BFG KM3s are 7.50 R16 LT Load Range E mounted on period-correct welded steel Bantam 5 on 5.5 bolt pattern wheels.
Quality Koyo bearings serviced since latest trip (new at restoration) and spares of bearings and seals included in vacuum sealed bag, already packed with grease.
The trailer is very light (fully loaded with tools and gear for a cross country month-long trip) it weighed only 1,180 lbs. It’s likely in the 7-800 lb range empty.
Color is the official Jeep color from 2013 models only (Commando Green) with professionally applied black bedliner inside, underneath, and to the frame and fenders. It is very well protected from the elements.
LED lighting, all new wiring, and original replacement Grote reflectors.
The lid seals the trailer contents very well from the elements (water, mud, dust, etc) and the entire tub is lockable with two keyed locks in the tailgate.
The tongue was replaced with much stronger than original C channel and 2” square tubing so an articulating offroad hitch can be used if desired. Spare tire mount is incorporated into the tongue as well with no stress to the body/tub itself.
Three BFG KM3 tires are PERFECT.
The tent is a Tepui Kukenam 4 ruggedized and is in perfect condition.
Ready to go.
$9,750
Madison, AL
Ready to go.
$9,750
Madison, AL
